The OFFICIAL 24v Engine Bay Thread
This is a sticky topic.
  • Drew325is
    • Oct 2004
    • 520
    #226
    Here's mine much closer to completion:
    • loonibab325i
      • Dec 2005
      • 770
      #227
      Looking good drew! I like your intake setup, care to elaborate on that?
      s52 0-150mph & more http://www.youtube.com/loonibab325i
      • e30s52
        • Oct 2007
        • 5235
        #228
        here is mine. not the cleanest though
        www.gutenparts.com
        • Drew325is
          • Oct 2004
          • 520
          #229
          Cheers!
          The intake is a BMA CDA filter, with a custom made spun aluminium bell mouth to allow it to go straight into the intake boot...I'm running Megasquirt 2 with a MAP sensor, so no need for a MAF sensor. It'll be good to get the car on a dyno soon.
          • loonibab325i
            • Dec 2005
            • 770
            #230
            Sorry for going OT, but megasquirt on a s52? how hard was install, what were the main issues with getting it working?? I always thought megasquirt was near impossible to run on a s52 for some reason.. something to do with vanos?
            • e30s52
              • Oct 2007
              • 5235
              #231
              i dont think you can run vanos with megasquirt.
              www.gutenparts.com
              • Drew325is
                • Oct 2004
                • 520
                #232
                Install wasn't too bad...it mostly uses the OEM harness. Vanos is fine, but it needs to be dyno confirmed that the switching points are correct. It still needs work, but I rarely get time to work on it these days (plus the dash is out of the car at the moment for an A/C rebuild)...but in spite of that it's working well...just not well enough to be screaming it's successes from the hilltops.
                • sheefo2k
                  • Nov 2008
                  • 97
                  #233
                  Originally posted by C ///M
                  Updated picture here. Still dirty and really bad lighting. I'm going to steam clean the bay when it gets permanently warmer.
                  I kow old post and stupid ( i ve done 2 motorswaps before in e46 and honda) but how does the car not over heat with no fan?
                  i never understood that.
                  Super E30 newb
                  • 416stroker
                    • May 2008
                    • 2448
                    #234
                    go read up on bimmerforums. they explain it all doesnt sound to hard.
                    84 318I Delphin RIP
                    87 325IS delphin 24v Sold
                    89 325 Alpineweiss
                    • tonytony
                      Knee deep in poopie
                      • Jan 2004
                      • 3498
                      #235
                      it will overheat if you sit still for a long time, but when the car is moving there's adequate airflow going through the fins to keep the temp stable
                      • sharksforthecup
                        • Aug 2007
                        • 246
                        #236
                        That and there could be a pusher fan on the other side of the radiator that we cant see. Thats how mine is.
                        • dude8383
                          • Jan 2005
                          • 10387
                          #237
                          so is that the correct positioning of the maf, where the harness plugs in and all?
                          • e30s52
                            • Oct 2007
                            • 5235
                            #238
                            yes it is.
                            www.gutenparts.com
                            • vodomagoo
                              • May 2004
                              • 286
                              #239
                              My race car
                              • So Live
                                • 2512
                                #240
                                Fuck me, i need to do a custom Rad Brace. I have way too much shit going on and everything could be so much simpler. Maybe this winter i'll cut my car apart.
                                100% Myth
                                But that said, MS sucks. At least splurge for VEMS then talk to multiplex on bf.c cause hes running VEMS on his ~600whp s52. Why run a multi-thousand dollar powerplant with a $300 solder-your-self computer?
                                Engine bay Update:
                                -Chris
