problem with e30 s50 supercharged tune and ews
  • Mesarina
    • Jul 2012
    • 268
    Originally posted by berlow94
    Just curious. Why are you using a 3.5" MAF?
    Never on any setup seen any gain in power or flow. You still have m50 manifold and 3" throttle body.
    It came with the kit, Better be on the safe side, Im pretty sure the stock maf will peg out quickly even at 6psi
    Originally posted by mr.vang
    If like any ews2 delete for 95 m50, you'll have to cut a wire coming from the DME if you run a red 413 chip on a silver 413. I believe its a solid green one. You can always Google ews2 delete and their should be plenty of Info's on it.
    The e30 already ran with an ews delete chip, problem is the chip that came with the supercharger has ews on it, the wire coming from the dme is already cut, you don't use it on a c101 plug when doing the conversion harness....
    • Mesarina
      • Jul 2012
      • 268
      Originally posted by golde30
      damn, there is the MAF and filter gonna go? maybe make a hole behind the high beam and run it down behind the fog light?
      The maf fits, the air filter is the problem, making a hole is not a bad idea, im looking for the smallest 3.5" to put in there, hope it doesn't affect the maf reading if it is close...
      • Mesarina
        • Jul 2012
        • 268
        Originally posted by L8 apexr
        Powerdyne.
        Bd11 or bd11a? What size are your pulleys? Or does it makes 9psi because of a different impeller? That would be my next step lol
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          Why not just add EWS in the car and align it. Would be a lot cheaper then getting a new tune. Or they also make EWS emulators but I have never used one or know how good they work.
          • nrubenstein
            • 3148
            To use that chip, you MUST add EWS to the car. You can use a non-EWS chip in an EWS DME if the car is wired right. You cannot ever use an EWS chip without a working EWS system.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • Mesarina
              • Jul 2012
              • 268
              i was looking at those emulators, but don't know if anyone has made one work... so I should buy this? and wire it up?
              http://www.ebay.com/itm/E36-1995-325...ce055d&vxp=mtr
              I know the antenna ring goes to the transponder with the two plugs on it, then the module reader to the ews, and from the ews to the dme pin 66? what more will the ews need to work? I could put the e36 key in the glovebox or something for added security, then I should only put the supercharged chip on that dme and it will run right? or does the chip also has a code from the car the supercharger was taken? time to do more homework...
              • Mesarina
                • Jul 2012
                • 268
                Correct me if Im wrong, but the supercharged chip will only work with the ews and key out of the car that had the charger before right?
                • golde30
                  • 11464
                  That's a good question...
                  IG: @Baye30
                  • BingM3
                    • 863
                    Get a used silver DME ending in 506 for '95 E36 M3, and not the 413...that would easily solve your issues since they had no EWS
                    I also have the same Powerdyne BD11 blower in my car, with 3.5 HFM
                    • L8 apexr
                      • Dec 2010
                      • 226
                      BD11 blower,just measured the pullies-bottom of the rib blower pulley is approx. 2.83" and the crank pulley approx 4.44".The unit was rebuild just before it was bought by the guy I got it from,he drove it about 6 months and crashed the car.The case isn't vented so I doubt it'll have a billet wheel in it,not sure just yet wether I'll run it as for a season(I'm Canadian so only drive the car occasionally for 6 months a yr)before I vent it and do all the upgrades or do it before I install it.
                      Hey Bing any pics/video of your set-up?.
                      • Mesarina
                        • Jul 2012
                        • 268
                        so I can use the silver 413 chip with the supercharged tune and ews on it, on a 506?
                        e30 too? pics would be great
                        you can take out the supercharger pretty easy to do it later, can't wait to see how my e30 moves...
                        • nrubenstein
                          • 3148
                          Originally posted by bingm3
                          get a used silver dme ending in 506 for '95 e36 m3, and not the 413...that would easily solve your issues since they had no ews
                          i also have the same powerdyne bd11 blower in my car, with 3.5 hfm
                          THIS IS ABSOLUTELY NOT TRUE. USING AN EWS CHIP IN A NON-EWS DME WILL NOT WORK.
                          That is the problem.
                          • Mesarina
                            • Jul 2012
                            • 268
                            that's what I tought, anyways, I'll be working with eurotuning.us, great customer service so far, ordered a 413 red label to make it easier, I already had an lc-1 gauge, so I will be ordering the controller and o2 sensor too, I didn't want to put too much gauges on my e30, but I'll have too, vdo boost gauge and lc-1 wideband in the asthray with a panel from jaywood
                            after I get everything in good working order, I may put an econoboost and no wideband to make things cleaner... already have an 180sx with too much gauges, don't need another car full of them...
                            • BingM3
                              • 863
                                • 34844
                                On an NA car..?
                                A 3.5" MAF will make more power when you are flowing so much air that a 3" MAF cant meter it all.
                                How do you suppose a 3.5" maf can flow more air through a 3" throttle plate?
                                Those gains come from the tune, not the maf.
