What gear do you dyno your swap in?
  • klodkrawler05
    • Apr 2012
    • 253
    Just curious what you guys have had your cars dyno'd at? Taking mine to a buddies shop tomorrow to see what it lays down and would like to be consistent with others on here!
    Its the g260 trans and a 3.73 rear end if that makes a difference
    Thanks!
    Brad
    P.S.
    If you want to play the over/under guessing game, my specs are below:
    S52
    TRM Tune
    21.5lb Pink Injectors
    Lightweight Flywheel
    OBD1 Intake Manifold/Throttle Body
    Bimmerworld 3.5" intake and AEM Dry Filter
    OBD1 Stock Exhaust manifolds (the OBD2 ones were cracked)
    2 glass packs right after the "X" pipe that joins both headers.
    No A/C, No Powersteering.
    No Manual Cooling Fan
    I'm going to guess 229whp/217wtq :o
    -Brad
    My E30: http://www.r3vlimited.com/board/show...50#post3916850
  • iansane
    • 1342
    You're going to have some pretty wonky readings if you dyno in anything other than yours trans' 1:1 gear.
    84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
    • 328ijunkie
      • May 2007
      • 3961
      4th is typical
      Check Us out on Facebook
      Full Product Line Tuning
      • matthugie
        • Mar 2004
        • 1810
        Should be 4th. Also, the type of dyno can shift the numbers up or down (mustang vs dynojet, etc.). Post your results!
        88 325is - S52 powered
        Originally posted by King Arthur
        We'll not risk another frontal assault, that rabbit's dynamite!
        • klodkrawler05
          • Apr 2012
          • 253
          4th it is!
          Thanks guys! I'll update with results tomorrow.
          -Brad
          • berlow94
            • Jan 2013
            • 1063
            My guess is 215 HP if its a dynojet. Good luck!
            The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
            • ForcedFirebird
              • Feb 2007
              • 8300
              4th gear as always.
              223/215
              john@m20guru.com
              Links:
              • e30rapidic
                • 2167
                '87 325ic, powered by S50.
                • JCarp90
                  • Feb 2011
                  • 1759
                  S52
                  OBD1
                  OBDII manifolds
                  2" exhaust
                  TRM chip
                  S2.93
                  ZF320
                  3rd gear
                  • iansane
                    • 1342
                    Originally posted by JCarp90
                    ZF320
                    3rd gear
                    Isn't the 1:1 gear on the ZF box, 5th? Why did you dyno in third?
                    • JCarp90
                      • Feb 2011
                      • 1759
                      Oh god. The 1:1 argument again.
                      • iansane
                        • 1342
                        I'm not sure how a simple question can be construed as an argument? I'm obviously ignorant here and genuinely asking you.
                        • klodkrawler05
                          • Apr 2012
                          • 253
                          Well obviously somethings not working right at this shops dyno.......these are the numbers graph I got.....
                          282whp/248wtq
                          I dyno'd in 4th which is 1:1 on my G260 trans........as far as I know I don't have cams.
                          anybody want to wager a guess why I'm so far off the numbers others have gotten?
                          -Brad
                          • JCarp90
                            • Feb 2011
                            • 1759
                            Hah, ignore me then. My spidey senses were wrong.
                              • 34844
                              I was going to say - I've dyno'd in 3rd, 4th, and 5th and the difference between the 3 curves was well within the margin of error.
                              I prefer 3rd because my car doesn't have the power to spin up the rollers very quickly in 4th, meaning I don't have to beat up the car so much by staying at high-RPM for an extended period of time until I hit the redline.
