Getting BAR'd Certified, Fail... HELP!
  • blackhawkimpact
    • 2415
    So I'm trying to pass my 91 318is with an s50 to pass the BAR test but I keep failing emissions. First time I took it, I warmed it for about an hour and when I got to the referee I kept it on. I was on stock e36 cats and resonator. First time I failed. 2 months later after I switched the plugs, oil filter I took it again to the referee and I failed again. So I thought I would change the cats. So I got new cats (Walker 80801, Suppose to be direcct fit for the 95 e36 M3), and a month later I took it again. Warmed it up the same way I did the first time. Not only did I failed the smog, referee said I got the wrong cats:hitler:. I was pissed. He saying that the cats are the wrong ones and that this year only uses one cat not two?? I didn't really pay attention after the test failed, but he said he called BMW and that they told him that the e36 M3 comes with 4 cats. His his book says that the cats I bought are for one cat cars or something like that. He said I also probably failed because of the cats being the wrong ones.
    My question is for people that are BAR'd and have aftermarket cats, what cats did you use?
    Parts replaced;
    O2 sensor
    Spark plugs
    Oil
    Cats
    Air filter
    19.5# Pink Injectors.
    Here are the Smog test results.
    1st test
    15MPH= RPM(1755), %CO2(14.5), %O2(0.3), HC PPM(85/256), CO%(0.50/0.49), NO PPM(695/1550) FAIL
    25MPH= RPM(2878), %CO2(14.7), %O2(0.0), HC PPM(50/66), CO%(0.47/0.18), NO PPM(717/107) FAIL
    2nd test (oil change, spark plugs, air filter changed, OEM e36 M3 cats)
    15MPH= RPM(1720), %CO2(14.7), %O2(1.3), HC PPM(85/205), CO%(0.50/0.52), NO PPM(695/661) FAIL
    25MPH= RPM(2856), %CO2(14.8), %O2(0.0), HC PPM(50/78), CO%(0.47/0.21), NO PPM(717/73) FAIL
    3rd test (walker 80801 cats)
    15MPH= RPM(1752), %CO2(14.9), %O2(0.3), HC PPM(85/158), CO%(0.50/0.18), NO PPM(695/474) FAIL
    25MPH= RPM(2854), %CO2(15.0), %O2(0.0), HC PPM(50/82), CO%(0.47/0.04), NO PPM(717/15) FAIL
  • franky2fingaz
    • Aug 2012
    • 117
    It seems to me that you might be burning rich.. . tuned?
    • blackhawkimpact
      • 2415
      413 red label DME with TRM chip
      • franky2fingaz
        • Aug 2012
        • 117
        you can't pass with that, the shit load of HC (hydrocarbons) means your chip is (as designed) dumping more fuel in the mixture for the power gains...
        • TheRealE30kidd
          • Jul 2010
          • 496
          Had the same problem. New cat fixed it.
          The Current Army
          -(UnderConstruction) 1991 330iS 24v S52 build thread
          -1992 325iC
          -1987 E30 Truck
          -1991 332iS (BecauseRacecar)
          -1988 Dinan M3
          -1988 325iX Tribute car
          -1989 320i Touring (S52/6spd)
          • blackhawkimpact
            • 2415
            So I put the stock chip back on and I should pass?
            • franky2fingaz
              • Aug 2012
              • 117
              if you are running stock cams and injectors then I wouldn't see why not... I would also limit the driving as rich mixes ruin cats early...
              • E30FreaK89
                • Apr 2006
                • 437
                I'm having the same problem with trying to smog mine as well... But I'm not going for bar yet.
                • E30FreaK89
                  • Apr 2006
                  • 437
                  update?
                  • franky2fingaz
                    • Aug 2012
                    • 117
                    that could also be your problem.... you have to start with taking the fuel map back to stock then see if CATS are 'efficient' .. in Ontario the testing is as anal as Cali's..
                    • blackhawkimpact
                      • 2415
                      No update yet. I am on vacation. When I get back ill put the stcok chip back and get back to you guys. Thanks
                      • suruba
                        • Sep 2013
                        • 159
                        what headers did you use? I'm looking to swap my s50 and need to know what headers will pass.
                        Dave
                        • hwy84
                          • Aug 2009
                          • 190
                          Pink injectors on an otherwise stock S50 plus aftermarket tune means lots of fuel being dumped, and high HC.
                          Do you have access to green tops and a stock chip?
                          Current:
                          1991 325i Sedan - S50 Swap
                          1988 325i Cabrio
                          Past:
                          1991 M3
                          1991 318is
                          1985 325e
                          • blackhawkimpact
                            • 2415
                            I do. Ill be changing those before my app on the 22. Thanks for your help.
                            • Wanganstyle
                              • 2828
                              Yup the wrong injectors and aftermarket chip = forever trying to pass smog.
                              Sent from my SAMSUNG-SGH-I337 using Tapatalk
