Getting BAR'd Certified, Fail... HELP!
  • blackhawkimpact
    • 2415
    Got this B**ch to the ref and still got BS HC numbers after replacing the chip and injectors. :-/
    • franky2fingaz
      • Aug 2012
      • 117
      What thermostat temp you running?
      If it's a low temp thermostat then you will run rich...
      • blackhawkimpact
        • 2415
        I think I'm running the 80c thermostat, not sure though
        • franky2fingaz
          • Aug 2012
          • 117
          I'm not sure what factory temp specs are after warm-up, but if 80C is below factory spec then engine runs richer, thinking it's still warming up.. . Plus don't forget if ran rich for some time then cats will be inefficient... you need a Laser thermometer and do some homework before throwing more $$ at it..
          Edit: according to pelican, they are 88C or 92C.. so it's possible if you're running a low temp thermo which most tuned chips call for then you're burning rich...
          • blackhawkimpact
            • 2415
            Can I be running that rich just because of a low thermo temp?
            • franky2fingaz
              • Aug 2012
              • 117
              yes it doesn't take much... again you could have crap cats and we are assuming all else is good and stock with no codes. Thermostat is cheap and worth a try.. this is problem solving, you must isolate the expensive fix if there is one..
              With a cold thermostat on a stock chip, it's like being on constant warm-up mode and too much fuel getting dumped in the cats, after saturation the fuel ignites and cats become 'critical' and inefficient...
              • blackhawkimpact
                • 2415
                Bringing this back up...
                So I haven't had any time or money to actually keep fixing the e30. I finally have some time and some saved money. Before I go and buy new cats I'm going to replace the thermostat to a stock 88c, spark plugs (NGK BKR6EK/2288), oil and also going to change the MAF to the stock MAF (currently running the 3.5 MAF). Previously I took off the pink injectors and TRM chip and it still didn't pass. I'm also running the red label 413 ecu, is this ok to pass smog or should I be getting the silver label 506? I've been reading a lot of threads on R3v about e30 24v passing smog test and getting BAR'd and a lot of people pass with the chip and pink injectors installed. I'm going to replace the parts this weekend and then take it to a friend's shop to run a pre-test.
                So far these are my attempts at passing smog
                Test 1;
                Red label 413 with TRM chip
                3.5 MAF with stock e30 airbox
                Headers
                Stock e36 m3 cats
                Pink injectors
                91 octane
                80c Thermostat ( Not sure if 80c or stock 88c)
                Test results: FAIL
                15MPH= RPM(1755), %CO2(14.5), %O2(0.3), HC PPM(85/256), CO%(0.50/0.49), NO PPM(695/1550) FAIL
                25MPH= RPM(287, %CO2(14.7), %O2(0.0), HC PPM(50/66), CO%(0.47/0.1, NO PPM(717/107) FAIL
                Test 2;
                Headers
                New Walker cats ( Ref said cats I bought weren't for the 95 e36 m3)
                Pink injectors
                91 octane
                Test results: Fail
                15MPH= RPM(1752), %CO2(14.9), %O2(0.3), HC PPM(85/158), CO%(0.50/0.1, NO PPM(695/474) FAIL
                25MPH= RPM(2854), %CO2(15.0), %O2(0.0), HC PPM(50/82), CO%(0.47/0.04), NO PPM(717/15) FAIL
                Test 3;
                Red label 413 with stock chip (no TRM chip)
                Headers
                Stock e36 M3 cats
                Stock green injectors?? (17.5)
                91 octane
                Test results: Fail
                15MPH= RPM(1720), %CO2(14.7), %O2(1.3), HC PPM(85/205), CO%(0.50/0.52), NO PPM(695/661) FAIL
                25MPH= RPM(2856), %CO2(14., %O2(0.0), HC PPM(50/78), CO%(0.47/0.21), NO PPM(717/73) FAIL
                • smooth
                  • Apr 2005
                  • 1940
                  Is 88 considered low or were you telling him that 80 would cause issue? I think I have an 88 but wondering what switching to 92 would do both positive and negative
                  Now that you're on a stock chip go back to 87 octane. Too high octane can increase HC
                  Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
                  • blackhawkimpact
                    • 2415
                    88c thermostat is stock, 80c is low
                    • mtech325
                      • May 2008
                      • 565
                      If you haven't seen this post, scroll towards the bottom of the page, some good info there:
                      Seems like you will need new cats however. To put it into perspective, my friend has an s52 obd1, stock maf, TRM chip, and 24 lb injectors, and 80c thermostat and his car passed very easily because of new cats. You can use the 413 red label.
                      You can try an 88c thermostat as the stock thermostat in the e36 is 88c or 92c depending on climate, but fresh cats and o2 sensor do wonders..........just not to the wallet!
                      • smooth
                        • Apr 2005
                        • 1940
                        I was editing my post as you were responding. Go back to stock 87 octane, too
                        • blackhawkimpact
                          • 2415
                          Yea, I've read that thread. I already have a new o2 sensor in there also. I ran the test with new cats but still failed. According to the ref the cats were not for the s50 so he said I wouldn't of passed the visual even if I passed smog, but failed regardless. But cats are cats so with new cats in there I should of pass smog, no? Or are cats different inside for different cars?
                          • smooth
                            • Apr 2005
                            • 1940
                            also, it's been sitting a while...did I read that right? Dump your old fuel into a container or use it up and fresh fill before you test again.
                            • blackhawkimpact
                              • 2415
                              Tank was on E on the days of the test so I had fresh fuel in there every time I went to the shop to take the test
                              • smooth
                                • Apr 2005
                                • 1940
                                Cats are cats you're right about that but you're running too high octane now that everything else is back to stock.
