M50 dme
  • Wanganstyle
    • 2828
    #31
    Originally posted by pazza
    Not really, I want to supercharge the m50 towards the end of next year. Just want to sort
    It out to avoid any issues later.
    May look at the miller war chip setup.
    I think you missed the point:
    Nv electronics do not have knock sensors.
    Vanos is a lovely feature to have; both top end and bottom end power increase.
    Miller war was availible for vanos 413 computer and setup; not for nv last time I checked.
    You could also mechanically remove the vanos / intake cam and convert the entire engine to non vanos
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    • pazza
      • Jan 2010
      • 66
      #32
      ok, had a look on the side of the block and no knock sensors.
      So my next question is, can a vanos head be fitted to a non- vanos block??
      if so is this what has been done here??
      E30/ 318i m10, e30 m50 & E34/ 520i m50
      • Wanganstyle
        • 2828
        #33
        Nv blocks dont have threads for knock sensors but the casting is there and can be drilled / tapped.
        • M-technik-3
          • 18946
          #34
          Yes to the last question. A vanos head will bolt on.
