engine stand
  • Balleristic31
    • Aug 2009
    • 4198
    Hold the crank bolt and loosen the 8 flywheel bolts
    -NICK
    • Mistawall
      • Dec 2013
      • 319
      Originally posted by Roysneon
      Remove the 8 bolts?
      You'll also have to take the starter off to put it on a stand.
      Edit sorry didn't see your previous post. Try putting the end of a pry bar in the tooth of the wheel and bracing it against something. That's what I had to do when torquing mine down. Worked ok
      gona give that a shot later.
      my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
      • Roysneon
        • 4505
        This is actually a much better idea.
        Originally posted by mbonanni
        I am a pursit now.
        • MR E30 325is
          • Dec 2008
          • 3300
          There should be a small hole on the drivers side of the engine, at the rear. It may be covered by a blue rubber-like plug.
          Rotate the crank bolt at the front until a small cutout is visible through the small hole, on the back of the flywheel.
          Place a deep well socket (10mm if I remember correctly) through said hole, into cutout on back of flywheel.
          Loosen bolts.
          More complex than simply placing a big wrench on crank bolt, but this method is the actual way it is done, and doesn't involve a second set of hands.
          My previous build (currently E30-less)
          http://www.r3vlimited.com/board/showthread.php?t=170390
          A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
          • Roysneon
            • 4505
            I am a pursit now.
            • Mistawall
              • Dec 2013
              • 319
              Loosen bolts.
              ok i will try this later then. THank you for the informationes:pimp:
              • Mistawall
                • Dec 2013
                • 319
                So im assuming i probly need longer bolts? This is an 80mm m12x1.75
                  • 34844
                  only if you like your legs.
                  • Mistawall
                    • Dec 2013
                    • 319
                    Figured as much.. guess im off to home chepo after work
                    • Axxe
                      • Aug 2004
                      • 3355
                      Originally posted by Mistawall
                      Im trying to get that thing off
                      That's an excellent job for an impact wrench. Also, keep an eye on the strap, I had a strap get cut on the edge of a fork once, now I use chains exclusively.
                      Keep it slideways!!
                      • Mistawall
                        • Dec 2013
                        • 319
                        i doubled up the straps just in case. also im in my work garage which has no access to an impact/ air gun unfortunately :( im just trying to get it on to the stand so i can start taking it apart inspecting/cleaning it and replacing some gaskets and seals as well as start putting on the c101 connector.
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          A socket and breaker bar on the front of the crank works well. Just let it rotate around and stop against the floor. No need to hold it.
                          • Mistawall
                            • Dec 2013
                            • 319
                            Sucsess! Does this look safe?
                            • Mistawall
                              • Dec 2013
                              • 319
                              To anyone that cares my engine is finally mounted on the stand! prepare for a new forum topic for all my noob questions trolling the forum have not answered! Thanks everyone for your responses!
