When the VANOS piston seal is worn, the intake cam cannot advance for more cam overlap. This has the effect that internal-EGR (exhaust gas recirculation) is reduced. With less recirculated exhaust in the intake stroke, you will have more air and fuel in the cylinder, but the absence of exhaust gas will increase the combustion rate. Since the spark timing occurs based on the assumed exhaust/air/fuel in the cylinder, the combustion will now be too fast and cause pinging. The pinging is detected by the knock sensor, which in turn retards the ignition with loss of power as a result.
My m50 is pinging. Running out of ideas.
So I replaced my fpr a few weeks ago. Of course that did nothing. I did notice that my fpr said it was supposed to run at 3.5 bar though. If my car is running at 3.1 bar and the engine calls for 3.5 bar could that be the problem?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
its 3.5 bar with no vacuum on it.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Your gauge is showing 3.2 bar so i would say your fine on fuel pressure. You can also do a volume test and see if the pump is flowing enough fuel.
What brand of fuel are you using? My car would ping like crazy with shell gas and run better with every other brand. Try a different brand and see what happens.Last edited by surebimmer; 10-24-2014, 08:08 PM.
No I'm still working on it I'm just about out of ideas. I have replaced everything that can affect A/F ratio and nothing makes any diffrence. I usually get gas at chevron but I will try shell for a while.
I have two more things I will try before I take it to a shop to pay some goons to tell me "I don't know what's wrong".
Compression test and possible replace the main external fuel pump or maybe throw in some other injectors.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
