My m50 is pinging. Running out of ideas.
  • Ryann
    • 3350
    #76
    Any updates?
    • Wishno87
      • 6025
      #77
      Swapped ECUs today. Almost seems to be worse now. Still need to buy that resister. Ryan have you checked yours out yet? It's right under your fuel rail cover.
      • Ryann
        • 3350
        #78
        Negative. I will this weekend. So, the idea is that the resistor gets hot and drops injector voltage which reduces duration? Er what?
        • Wishno87
          • 6025
          #79
          Not exactly sure. It goes on the ground that attaches by the vanos. I was told that someone had similar issues and fixed it by replacing that resister so I'm just following any leads I can get now.
          • Dj Buttchug
            • Jun 2010
            • 7688
            #80
            mines detonating again... FML
            I cannot for the life of me distinguish the noise between pinging or vanos noise. Its extremely faint but its there especially under load at freeway speed like previously stated.
            I have done
            new plugs NGK
            new O2
            all New coil packs BAV auto
            fuel pump is new TRE 304
            always 91 fuel
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • meanEG
              • Oct 2013
              • 562
              #81
              i would put knock sensor on if you havent yet.
              Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
              • Ryann
                • 3350
                #82
                Mmkay. We are either lean on fuel, or spark is too far advanced for the effective CR. Has anyone verified damper/CPS tone ring position at TDC1?
                • Wishno87
                  • 6025
                  #83
                  Just checked the E34 and it also has a damaged resister.
                  • pmat
                    • Nov 2012
                    • 174
                    #84
                    vanos. mine pinged like hell on accelleration, resealed vanos and its all gone.
                    318is, m50tu g240 s3.46
                    • Wishno87
                      • 6025
                      #85
                      I bought all the parts to do it so hopefully that will fix it.
                      • ak-
                        • 12422
                        #86
                        An AFR gauge install would nice and always beneficial
                        1991 325iS turbo
                        • Wishno87
                          • 6025
                          #87
                          My podi is setup for it but I haven't bought the wideband yet because I can't get any of the rest of the gauge working.
                          • Ryann
                            • 3350
                            #88
                            Why would faulty VANOS cause this?
                            • Matt-B
                              The Waffler
                              • 3856
                              #89
                              Any updates?
                              • Wishno87
                                • 6025
                                #90
                                Ordered the last two resisters in the country right now. Sorry guys.
