My m50 is pinging. Running out of ideas.
  • Matt-B
    The Waffler
    • 3856
    #91
    So if anyone wants more, your saying hanz and franz will have to strike a few more, from the fire filled forges of the german mountains, where they harvest precious metals to use only on bmw parts??
    • Wishno87
      • 6025
      #92
      Just installed this.
      • THEhomelessONE
        • Oct 2013
        • 303
        #93
        Did it fix the pinging?
        RIP 02/25/15
        http://www.r3vlimited.com/board/show...16#post4356816
        • Wishno87
          • 6025
          #94
          Appears to be no change.
          • e30austin
            • 15382
            #95
            I knew it wouldn't.
            How did the rest of your sensors check out?
            • justin_l_
              • Jun 2007
              • 1079
              #96
              Originally posted by Wishno87
              My podi is setup for it but I haven't bought the wideband yet because I can't get any of the rest of the gauge working.
              I got the one I have all set up if you think I can help send me a pm.
              • Matt-B
                The Waffler
                • 3856
                #97
                Originally posted by Austin!
                I knew it wouldn't.
                Should have said something...
                • e30austin
                  • 15382
                  #98
                  It would have needed replacing eventually. Did you ever check out your knock sensors? How about cam sensor?
                  • Wishno87
                    • 6025
                    #99
                    Knock sensors are new. Haven't touched the cam sensor. Will do the coolent temp sensor next time I pull the intake. At this point I'm betting on the vanos. Replacing it next weekend along with some s50 cams and squid tune.
                    • e30austin
                      • 15382
                      #100
                      I would check resistance on the cam sensor, just to be safe. Good luck! You'll want to drive it a lot more after you do cams and a tune.
                      • butters
                        • 1206
                        #101
                        Damn, this sounds frustrating. I'm in just to see what happens, hope you can sort it out.
                        Seafoam didn't do anything for me either; I had my motor rebuilt afterwards and the pistons and valves were still horrifyingly caked with deposits, though to be fair it was burning significant oil. Also I didn't experience any pinging despite a that and a bad HG / poor compression.
                        I would check resistance on all the things just to be safe. Seems like it could be one of those terrible electrical gremlins we all dread.
                        You mentioned it was different/worse on a different ECU - does it change much when you unplug the battery for awhile then try again? I wonder what the adaptations are doing, maybe that holds a clue.
                        • Wishno87
                          • 6025
                          #102
                          I ordered a new cam sensor to install while I'm replacing the vanos unit because you need to remove the vanos solenoid anyway. I couldn't find any ohm specs for the cam sensor though. Just the crank sensor.
                          • Wishno87
                            • 6025
                            #103
                            Well it appears the rebuilt vanos and new cam sensor did nothing. I will still install the rebuilt vanos on the e34 though just because it probably could use it so I will report back with that.
                            Also yesterday I installed a new ecu coolent temp sensor and new oil cap as well as swapped coil packs. Still nothing.
                            Today I will swap injectors and fpr.
                            • Matt-B
                              The Waffler
                              • 3856
                              #104
                              damn... :(
                              I hope, you can track this down, is it possible, you have bad lifters, or a related head issue?
                              • Dj Buttchug
                                • Jun 2010
                                • 7688
                                #105
                                my shit pings still too. Im over trying to fix it. Im gonna mash it till it blows up.
                                Whatever.
                                Turbo M42 Build Thread :Here
                                Ig:ryno_pzk
                                I like the tuna here.
                                Originally posted by lambo
