Lifters sound REALLY BAD!
  • M3PO
    • May 2012
    • 537
    Hey guys, just started my S50 in my E30 for the first time. It sat on a stand for two years before I started the swap. It's filled midway on the dipstick with M1 0-W40 European. The lifters are so noisy it sounds like a diesel.
    I've let it idle for a few mins and revved it up half a dozen times. It seems to get a little better after revving it but then they get loud again. It's got a VAC baffle in the pan and I welded the oil pump nut.
    I got about 20 psi oil pressure at idle. Goes up to 60-70 psi when I rev it.
    Thoughts? Are they sticky from sitting? Wrong oil?
  • Vivek
    attention whore/retard/bitch
    • 6167
    That oil sounds really thin especially cold. That could likely be the issue.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • M3PO
      • May 2012
      • 537
      It's a 40 weight oil and seems to be pretty popular on the E36 M3 forums. It's a very good oil, I run it in my E92 M3 in place of TWS.
      • Liquidity
        • May 2014
        • 395
        40 weight oil is not thin.
          • 34830
          I'll bet the lifters are stuck/collapsed. I doubt it's the oil. not sure what you can do about it - can you pull them out and pop them free with an air compressor maybe?
          • plain325
            • Mar 2004
            • 163
            My engine sat for a few months before i started in initially. The lifters were noisy to the point where i thought there was a problem. Eventually they got quieter, after a few short drives and idling for a while.
            • AndrewBird
              The Mad Scientist
              • 11897
              Are you sure it's lifter noise? Could be chain rattle from a bad tensioner or vanos rattle.
              Might try this:
              It really helped with my lifter noise.
              • e30rapidic
                • 2167
                run a quart of ATF in it and follow the bleed process.
                1.) Bring the engine up to an operating speed (no load) of 2000-3000 rpm and maintain this condition for three minutes (bleeding procedure).
                Let the engine idle for 15-30 seconds and reevaluate whether the noise is still present or not.
                2.) Engine quiet – procedure is finished.
                3.) Engine noise is still present – repeat the procedure; perform steps #1 and #2 up to a maximum of 5 times.
                '87 325ic, powered by S50.
                • Lof8
                  • Oct 2006
                  • 2827
                  A loose spark plug in the 24v engines makes a similar noise to lifters. Check your spark plugs. This advice saved me once.
                  S50'd
                  Originally posted by TDE30
                  What is this faggy shit I have happened upon?
                  I can always live in a M3. Can't M3 a house.
                  • meanEG
                    • Oct 2013
                    • 562
                    This is all you need to do, nothing else. To a "t"
                    Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
                    • Vivek
                      • 6167
                      Yeah that's true my bad. It was late and I had just gotten home from a concert.
                      What exactly does the bleeding procedure do? Is it to get air out of the oil pump?
                      • M3PO
                        • May 2012
                        • 537
                        Thanks guys, that's what I was thinking I would do, I just didn't want to run it with it sounding like this unless I had confirmation first. Don't want to damage anything.
                        • Roysneon
                          • 4505
                          My father is an old mechanic and has mentioned this to me before. I've never had to try it but my new replacement m50 is doing this, so I'm going to have to give it a try.
                          Originally posted by mbonanni
                          I am a pursit now.
                          • M3PO
                            • May 2012
                            • 537
                            I checked the plugs and they were tight. I'm gonna overfill the oil a bit and try to bleed the lifters before adding ATF. I don't want to waste $40 in oil and a filter if I can avoid it.
                            • meanEG
                              • Oct 2013
                              • 562
                              Its OK to run atf for a full oil change for 1 qt of oil as a replacement. It will start to clean sludge if you had some cooked oil/sludge in the engine. No need to over fill oil. All your doing is bleeding the air out of the lifter. The noise you hear is the lifter collapsing when the cam squeezes it between the valve. When it fills with oil it really doesn't collapse.
