sent my M52 to the machine shop, gave it back with a bag of dowels. please help!
  • Kaiser soze
    • Jul 2011
    • 33
    after picking up my machined block and head, I got a small baggy with these dowels in it, ive searched my bently for help but haven't found any definitive information on them. two larger ones, and two small solid ones. I believe one is between the head and block but im unsure on the other ones. anybody have any of those detailed and labeled black and white photos that may help me figure out where these things go? hoping to put this back together in the next few weeks
  • atldohc
    • Nov 2008
    • 359
    Sleeves like that will usually be used to help locate the head on the
    Block, or the trans bell housing to the engine block. I'm not sure about the smaller pins, maybe the flywheel to help position the clutch pressure plate? What did the machine shop say?
    • mitchlevy7
      • Aug 2011
      • 672
      the two small ones go through the timing cover on the front. you will see the holes in the timing cover and the block.
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
      • Kaiser soze
        • Jul 2011
        • 33
        It's not from timing cover, those are still intact
        • Kaiser soze
          • Jul 2011
          • 33
          Bump
          • 2mAn
            Señior Mod
            • 21080
            the two hollow round ones go on the block and position the head, not sure about the two pin ones
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • SoundByte
              • Jan 2013
              • 335
              What kind of machine shop doesn't give you an explanation when they pull a fistful of bits out of your motor? That sucks.
              • Kaiser soze
                • Jul 2011
                • 33
                Yeah. Slightly upset about it. I know there's some in the timing cover but those are still in the cover. I don't want to start assembling the motor and find out those dowels were needed early in the process.
                • Spitfi-r
                  • 132
                  Did they replace them and give you the old ones back?
                  I got lots of parts back from the machine shop.
                  1991 318is sold!
                  1989 325=track car--S52'd
                  Durango R/T for towing.
                  >>>Build thread<<<
                  M235i daily driver
                  • Kaiser soze
                    • Jul 2011
                    • 33
                    They didn't replace them. I just need to figure out where they go ASAP. I've searched for diagrams and pictures and can't find exact locations
                    • King Mufasa
                      • Sep 2012
                      • 530
                      Got a brighter picture? cant tell with my vision..
                      • justin_l_
                        • Jun 2007
                        • 1079
                        Have you tried to ask the shop yet?
                        • e30rapidic
                          • 2167
                          i've got the old head i pulled off my S50, i'll look at it tomorrow
                          '87 325ic, powered by S50.
                          • E30NJ
                            • Aug 2013
                            • 921
                            This happened to my friend and they swapped the dowels around to line up the trans, so when we went to line up the trans it was a real fight for an hour. Good luck, I'd like to know why machine shops do this.
                            • e30rapidic
                              • 2167
                              the #1's are the dowel locations
