Adding oil pressure & oil temp gauges, how?
  • 2mAn
    Señior Mod
    • 20892
    Wiring for both seems straight forward, but Im curious where you will get the readings from?
    I am thinking about buying a spare oil filter housing to use, but not sure where to drill and tap.
    Has anyone done this? pics? tips?
    TIA
    -Simon
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
  • Gnarles
    • Dec 2008
    • 342
    easiest solution is to get an oil distribution block such as:
    This replaces the oil pressure sensor on the oil filter housing and has space for two additional sensors.
    • reelizmpro
      • 9551
      You have an S50 swap right? Fuck I can't remember who has what anymore. If u do then get a distribution block like JT designs. Ron Stygar and Jim Powell have great write ups on installing vdo gauges on m/s 50 engines.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • 2mAn
        Señior Mod
        • 20892
        That is PERFECT! If I read it right, I can mount both of my senders there for temp and pressure! thank you!!
        Mine is an aluminum M52 with S52 cams. Im the only one who has it, anywhere! betta recognize
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        • Gnarles
          • Dec 2008
          • 342
          you can mount both senders on the distribution block, but I would remote mount the pressure sender as it's quite big and heavy. I have mine mounted on the driver's side shock tower with a stainless braided line connecting it to the distribution block.
          • 2mAn
            Señior Mod
            • 20892
            sounds good. Do you have any pics?
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            • mcdougal
              • Nov 2014
              • 251
              I bought one of these. Haven't used it yet but seems like it should do the trick.
              We are the source for the highest quality in BMW performance parts and accessories, including BMW armrest covers and boots.
              I'll probably tap the on at some point for temp.
              • Nick_S
                • Apr 2011
                • 3658
                The rally road one I came across awhile ago and seems a decent affordable option.
                91 318is M50 swapped
                05 Honda Pilot
                24V swap thread
                • f4tj0n
                  • May 2013
                  • 411
                  my motor came with the JT Designs unit. Lucky me
                  • M3PO
                    • May 2012
                    • 537
                    I've been driving the piss out my S50 for a year on urethane mounts with the pressure sender mounted right to the filter housing. I bought the VDO one with the dummy light switch which I have hooked up to the stock cluster light.
                    No oil temp gauge yet, still trying to decided how to get an accurate reading. I'm not sure about those disto blocks since they don't position the temp sensor in contact with flowing oil.
                    • mcdougal
                      • Nov 2014
                      • 251
                      The oil temp sensor really needs to be in the pan.
                      • luckysnafu
                        • Jun 2008
                        • 262
                        Another option is to get an oil filter housing from a Z3M S52 which has a port for the oil temp sensor built in. Then you can add a pressure sensor to the oil warning light port and you are all set.
                        http://www.realoem.com/bmw/showparts...39&hg=11&fg=30
                        Looks like you can buy a brand new one online for under $200 (ECS Tuning) or find a used one at a junkyard or on ebay.
                        M/S52 Wiring Diagrams
                        Z3M S52 to late model 325i wiring diagram
                        M52 to 318is wiring diagram
                        • 2mAn
                          Señior Mod
                          • 20892
                          Thats awesome! I like that better
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          • Gnarles
                            • Dec 2008
                            • 342
                            here's a good thread from bfc on remote mounting the pressure sender. You may be ok direct mounting it to the distribution block, but why not do it right the first time and not risk a failure.
