NC325iC 24v build thread
  • NC325iC
    • Mar 2004
    • 6565
    I gave a question regarding routing the obd2 fuel injector harness through the m50 manifold and that question is, how do you do it? Anyone have some pics of that area?
    • NC325iC
      • Mar 2004
      • 6565
      Next question, I got the subframe reinforcement plates from akg. Figured id go ahead and beef up those tabs. My friend tells me that I will only be able to use the top side plate and not the lower gusset because the motor mount comes through the slotted hole for 24v swap and the gusset blocks that hole so i would not be able to tighten the nut on the mount.
      How are people getting around this?
      • FredK
        • 14762
        You have to heavily modify the bottom plate if you want to use it with stock 535i rubber mounts. It is way easier to clearance it before you install it, so check that a socket fits before you weld it in.
        • NC325iC
          • Mar 2004
          • 6565
          Alright, next question.
          How are people securing the dipstick tube?
          • NC325iC
            • Mar 2004
            • 6565
            Anyone with a dipstick solution?
            • NC325iC
              • Mar 2004
              • 6565
              How do people secure the dipstick tube?
              Sent from my Nexus 5 using Tapatalk
              • KI4UJO
                • Jun 2011
                • 642
                It mounts to the front intake support bracket.
                IMG_0145 by Jonathan Martin, on Flickr
                • NC325iC
                  • Mar 2004
                  • 6565
                  A picture would be much appreciated. Mine seem to be too far apart to come together.
                  • schmidty
                    • 1253
                    Hey man, I wouldn't mind seeing your build sometime.
                    I just started an m52 swap on my e30... would be nice to see what progress you've made and what kind of roadblocks you've hit
                    • NC325iC
                      • Mar 2004
                      • 6565
                      Sure thing. I just put the engine and trans into the car yesterday.
                      • Sh3rpak!ng
                        • Jan 2014
                        • 2667
                        I made a small bracket out of mild steel I had laying around to bolt the dipstick tube to the IM since I am not using the support brackets
                        Shadetree30
                        • NC325iC
                          • Mar 2004
                          • 6565
                          Photo update.
                          I figured out last night that people cut the 318 wiring covers to fit over the intake manifold.
                          I am nervous about the exhaust though. I can't see how it will work here. Anyone have pics using the s52 headers?
                          • M3PO
                            • May 2012
                            • 537
                            Get the bracket from the 5-series that the pan came off of.
                            edit: I tried to take a pic of mine for you but there's too much stuff going on under there.
                            • Sh3rpak!ng
                              • Jan 2014
                              • 2667
                              Photo update.
                              What exhaust components are you planning to use?
                              OBD2 headers will fit with no problem.
                              Edit: from your first post it looks like you're planning on using obd2 headers + custom everything else? You'll be fine. Most annoying part is finding flanges to bolt up to the headers - I robbed them from a junkyard and built my own exhaust
                              Shadetree30
                              • NC325iC
                                • Mar 2004
                                • 6565
                                Well I was hoping to get the downpipes from an e36 and graft then on to a custom center section
