NC325iC 24v build thread
  • NC325iC
    • Mar 2004
    • 6565
    #46
    Idle problem located. Brake booster vacuum leak in the cabin. I can hear it. Tested by plugging the booster vac port and letting it idle. Looks like this booster is no good.
    Question about booster less brakes, can you keep abs?
    Sent from my Nexus 5 using Tapatalk
    • 2mAn
      SeƱior Mod
      • 20988
      #47
      Just get a good iX booster. OEM brake feeling. Thats what I use.
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • NC325iC
        • Mar 2004
        • 6565
        #48
        I like the breaks feel of the 944 booster, just don't want it to leak
        • Northern
          I like cupcakes & sh!tboxes
          • 5278
          #49
          Do people running e36 slave cylinder us the e36 master as well?
          No, I'm running E30 master, 328i slave. FX racing Stg3 kit, new oem bearings with new pivot/fork/seals for ref.
          Originally posted by priapism
          Originally posted by shameson
          • NC325iC
            • Mar 2004
            • 6565
            #50
            anyone have info on boosterless+ABS?
            • FredK
              • 14762
              #51
              Yes, boosterless brakes work with ABS.
              In my opinion, if you can retain a booster, do it. It's a little easier to modulate at the limit.
              • NC325iC
                • Mar 2004
                • 6565
                #52
                Alright then. Guess I need to start looking for parts ome way orbthe other. Stupid leaky booster....
                • glucklich21
                  • 1912
                  #53
                  Rockauto has a remanufactured IX/735i booster for $150 w/ the core charge.
                  • NC325iC
                    • Mar 2004
                    • 6565
                    #54
                    Good to know
                    edit: iX booster is not for me, dont want a new MC. Gonna try another 944 and not turn the shaft so much that i break the diaphragm
                    • M3PO
                      • May 2012
                      • 537
                      #55
                      The new master is bolt on if your old one has two lines going into it. My '84 had three so I had to tee the two front lines together which is more difficult than it sounds.
                      • NC325iC
                        • Mar 2004
                        • 6565
                        #56
                        I ordered a rebuilt 944 unit from summit for about the same price.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          #57
                          OK so I need some more help here.
                          Throttle cable. My throttle is sticky at the top of travel, and it isn't smooth traveling. I cleaned and lubed the throttle body and no improvement.
                          I think the issue is that the e34 throttle cable is too long. I have to loop it to get to the throttle body, and this could be causing the poor actuation. What cables are other people running? Any pictures?
                          Sent from my Nexus 5X using Tapatalk
                          • M3PO
                            • May 2012
                            • 537
                            #58
                            That's strange because my E43 throttle cable is the perfect length.
                            • NC325iC
                              • Mar 2004
                              • 6565
                              #59
                              Are you obd2 throttle body?
                              • M-technik-3
                                • 18946
                                #60
                                I use the e34 cable much like everyone else with no issues. What linkage setup are you using?
