reground cams
  • hoveringuy
    • Dec 2005
    • 2743
    reground cams
    Anyone have any experience?
    Specifically, if I want to gain .5mm of lift by reducing base circle will the lifters accommodate that in their normal tolerance? When are lash caps required?
  • Northern
    I like cupcakes & sh!tboxes
    • 5277
    I've heard of elgin cams and riot racing as having good turbo regrinds. I've never heard lash caps mentioned for either of them.
    Riot Racing I see that their cam prices have jumped by ~$200 though, they used to be $400 with a $350 deposit...
    Elgin Cams No prices listed, they used to be sold through DynoSpot Racing
    Other than those, I've never heard of anyone else using regrind cams.
    Originally posted by priapism
    Originally posted by shameson
    • hoveringuy
      • Dec 2005
      • 2743
      VAC says they don't use lash caps for anything under 1.5mm on hydraulic lifters.
      • 328ijunkie
        • May 2007
        • 3961
        Ive heard you can get away with ~.7-1mm...
        Weve also installed a few sets of RR regrinds without issues.
        Check Us out on Facebook
        Full Product Line Tuning
