Can't figure out this misfire
  • NickL
    • 562
    Fixed. Vanos Solenoid.
    1987 325is - S52
  • sublimation
    • Jul 2013
    • 155
    Misfire at idle or when revving up / under load?
    • ian e30 318is
      • Mar 2007
      • 1809
      Maybe try different plugs. What are you currently using? I switched to NGK and my idle improved and made a slight hesitation disappear.
      1991 LS1 Swapped 318is
      Instagram:
      https://instagram.com/saltybeast/
      LS Build Thread:
      https://www.r3vlimited.com/board/for...s-e30-ls1-swap
      • Sea Aych
        • Apr 2013
        • 765
        Does it miss consistently now or does it happen intermittently?
        1988 Atlantisblau Euro/Japanese 325i Cabriolet
        1989 Schwartz 325i - now M50 powered! - now very dead
        1998 Toyota 4Runner Limited
        My 17,000km Big NA National Parks trip!
        • M3PO
          • May 2012
          • 537
          I had a slight misfire at idle on Bosch coppers and NGK plugs cured that for me too. I had a misfire at WOT above 4000 rpm that was caused by a cracked coil boot.
          • ky0u
            • Dec 2012
            • 808
            Had the same issue. Misfiring when spark breached the insulation and arched
            Web Designer / Front End Developer
            My Portfolio & Website
            IG: @w_illriderz
            • 5Toes
              • 9836
              it might be an intermittent crank sensor, coil packs likely are good if you can change the idle with each one. maybe try rebuilding your injectors for good measure - mepeh here on the forum can do it for $45 or so total.
              • M3PO
                • May 2012
                • 537
                Mine would change the idle because they were firing. But at high RPM the car would misfire horribly and break up. The damage to the coil boot seemed really minor but it was enough to cause a major problem.
