S52 OBD1 Crank Position Sensor Question
  • BritishMike
    • Sep 2014
    • 47
    So I'm sorta new to the forum, I mainly use it for researching rather than corresponding with other members so I maybe not in the know with everyone. But do we have a resident electrical, know-all guru? I have a Crank Position Sensor question. I'm getting ready to drop in a S52 previously converted to OBD1 in an E36 M3. I know I have the correct OBD1 harness. And from what I read the M44 CPS is a plug and play option. My questions is the M44 was OBD2 engine will this sensor be plug and play with my OBD1 ecu and harness? I have a CPS sensor in the rear mount currently but it doesn't have a tail so I'm guessing thats one from the S52?
    -Mike
    Build Thread:
  • BritishMike
    • Sep 2014
    • 47
    Bump Anyone?
    • 2mAn
      SeƱior Mod
      • 20985
      Im pretty sure the plug in the rear mount is the OBD2 setup, OBD1 has a front trigger wheel
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • M3PO
        • May 2012
        • 537
        I'm exactly sure what you are asking but my OBD1 S50 has the CPS on the front with a trigger wheel on the crank.
        • BritishMike
          • Sep 2014
          • 47
          Im referring to this post, my next step is to resurrect that thread and see if I can get anyone to answer. I under stand the front mount however if I can Id love to run the rear mounted sensor since I have an S52.
          • kronus
            • Apr 2008
            • 13032
            the cps that's just a plug is the OBD2 S52 rear mount unit.
            sounds like that thread has all the answers to your questions - it's plug and play.
            cars beep boop
            • BritishMike
              • Sep 2014
              • 47
              Sorry if this all sounds dumb and simple, wiring or electronics in general is not my thing. I was also reading in another thread where by passing a connector and soldering wires together or creating own connectors can cause issues too. Thats why I was curious if this will plug into my harness.
              • M3PO
                • May 2012
                • 537
                From reading that thread, it sounds like the M44 sensor is a plug and play solution for you.
                • BritishMike
                  • Sep 2014
                  • 47
                  I was able to sort to exact info I was looking for.
                  The part number is here 12141247622.
                  Maybe this will make it easier to find for someone in the future.
                  Thanks everyone!
                  -Mike
