Turbo time for my S50 on a "budget"
Looks good! I'm really interested to see how you setup the S54 oil filter housing. Are you using an aftermarket cooler or the stock 325i setup?Comment
1989 332IS -S-Fiddy Four-Some weight removed.
5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.Comment
So I can feel the budget monster creeping up on me.
Oil pump is toast.
Rods and mains looked fine. Took the block crank and Pistons to the machine shop to get looked at.
Not to bad for 8-10k really hard miles.
Have this in my back pocket in case the pistons or rods don't look so hot.
http://www.cnc-motorsports.com/je-pi...s-pistons.html1989 332IS -S-Fiddy Four-Some weight removed.
Oil pump is toast.
Looking more and more like you put budget in the name to be sarcastic [emoji23][emoji23]
- S50 Swapped E30 1/1 Mineral White -@vaughnbannister on IGComment
definitely better safe than sorry to have the block machined. iirc for a flat 6 the side to side surface tolerance is .002" and lengthwise is .006" (and those figures are for head and block combined) so that block was out of spec anyway.
scope creep is a bitch, but you'll be all smiles when it's finishedComment
Killing all the subaru kids around here is the best, although 250whp does that in an e30. Looks like some awesome progress, going to be killer.
Think it will make the first autocross?
Not sure right now. Trying not to rush. I am taking the opportunity to clean a lot of stuff up. Deleting unnecessary wiring etc.1989 332IS -S-Fiddy Four-Some weight removed.
Trust me, it's going to be great, having my supercharged set up at around 400 wheel was awesome. Killing 99% of cars on the road, best feeling [emoji41]
I have the S54 housing also. They make an AN adapter so you can do a really clean setup with an aftermarket core. Sorry, I don't have any good pics of the adapter setup. PM me if you really want some.
Also just got back from my machine shop. He said my head work looked great but there was more that could be done but it wasn't needed as I am going FI. I am super lucky to have my machine shop. They actually have an torque plate for my engine. I knew it was a good shop when I saw two S50B32 blocks sitting by the door custom drilled and tapped for oil squirters. He also has the ability to engine dyno an s54 too. The shop has build NA S54's that make 420+ hp.
For my engine It looks like I will likely be going with rods and pistons and officially taking the budget part off of the build.
More parts to sell1989 332IS -S-Fiddy Four-Some weight removed.
Well, while its at the machine shop, port and polish the head. The heads on our motors really benefit from it especially the exhaust side.
