Turbo time for my S50 on a "budget"
  • M3PO
    • May 2012
    • 537
    #31
    Originally posted by BMW_TUNER
    I like your cooler. Do you have the specs on it.
    It's the Setrab 19 row core. It's 13"x6". I have it mounted so that the bottom of it is level with the bar that splits the lower grill area. If I had the inlet and outlet on the top, it could be mounted lower, completely in front of the lower grill. As is, it holds 200F in the canyons in cool weather. Haven't tried it on the track yet.
    • BMW_TUNER
      • Jul 2006
      • 1385
      #32
      No the planning begins.
      1989 332IS -S-Fiddy Four-Some weight removed.
      5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
      • BMW_TUNER
        • Jul 2006
        • 1385
        #33
        Bye bye budget..... To a certain extent. Ordered JE 9:1 pistons and K1 rods today. Things should pickup speed in the next few weeks.
        • vaughnbannister
          • Aug 2012
          • 206
          #34
          I feel you [emoji24] excited to see more.
          - S50 Swapped E30 1/1 Mineral White -
          @vaughnbannister on IG
          • vaughnbannister
            • Aug 2012
            • 206
            #35
            Have you got your gauges sort out yet?
            I have VDO gauges but they are just simple, wanting something more with like a warning light that flashes or something like that for boost/ oil pressure and so on.
            • exhaust
              • Jun 2015
              • 411
              #36
              This hits me right in the feels. Its fun to remember back when I was "just gonna swap it"
              • vaughnbannister
                • Aug 2012
                • 206
                #37
                ALWAYS turns in to the "well, while I'm in here..."
                • BMW_TUNER
                  • Jul 2006
                  • 1385
                  #38
                  Seriously. I started off with "well I will just deck the block then put it back together". HAHAH. Now its
                  Deck Block/Clean Block repaint
                  Deck Head/wash Head
                  Torque Plate Hone to 86.5mm - This one was a huge learning experience for me. The engine builder explained that when the S and M blocks are TQ plated with studs some of the cylinder walls bulge a couple of thousandths out and thus impact ring sealing and longevity.
                  Spin polish check Crank and check for Tolerances.
                  Purchase JE 9:1 Pistons 86.5mm
                  Purchase K1 Rods- recommended as superior over the Eagle (his word not mine)
                  Pricing was actually pretty good on the Rods and pistons.
                  Purchase new flywheel, clutch, pressure plate - Grip Force Stage 3 (know a few people who have had good experiences with the Grip Force Stuff)
                  Take whole rotating assembly back to engine shop to have it rebalanced as many many grams will be coming off of the assembly.
                  Then reassemble and spin to 7400rpm
                  • BMW_TUNER
                    • Jul 2006
                    • 1385
                    #39
                    I am in the same boat on the gauges front and I want to be able to data log as I will likely be going with RK for the Tune. I am looking at the SCG-1 and the Turbo smart Eboost 2. I love the boost 2. Also still not happy with the mounting options for the E30 I will probably mount in the center vent just to keep it in my eye line.
                    • vaughnbannister
                      • Aug 2012
                      • 206
                      #40
                      So this is an old pic, but this is where mine is(have my AFR there now as well) and I'm not sure if I like it anymore. But having it in the vent makes it so you don't have the vents anymore and I don't want that. Leaning more to the A-Pilar but eahhh
                      • M3PO
                        • May 2012
                        • 537
                        #41
                        Oil temp, water temp, oil pressure
                        • vaughnbannister
                          • Aug 2012
                          • 206
                          #42
                          See, I don't really know how I feel about looking down to see the gauges. I have my oil pressure there and when I blew my motor it helped 0% [emoji30]
                          • M3PO
                            • May 2012
                            • 537
                            #43
                            I have a VDO sender that has the dummy light switch built in so it pops up on the dash if the oil pressure drops below 7 PSI.
                            • BMW_TUNER
                              • Jul 2006
                              • 1385
                              #44
                              Got my clutch in today. I will swing by the engine shop tonight. Pics coming. Let the money flow.
                              • vaughnbannister
                                • Aug 2012
                                • 206
                                #45
                                Getting the clutch balanced ?
