s52 swap
  • xPreciouS E30x
    • Mar 2016
    • 11
    s52 swap
    Hey there guys I have a 90 e30 and want to swap It out with s52 . Does anybody know if there will need to be any cutting of tunnel for the tranny or engine . Or does it fit with no problems only motor mounts. Plz if any info needs sum tips about it. Thxz.
  • JasonC
    Site Manager
    • 14451
    Moved to the correct part of the forum..
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • stonea
      • 2892
      For the love of god search..... The M/S5* swaps are the most done swap on here. Just search next time or read a build thread. To answer your question.... No
      My Garage
      Feedback
      Instagram: Stone.Hopkins
      • roguetoaster
        Biggus Tippus
        • 7822
        E30s are just like Hondas. As long as you're replacing an engine with the same type as you removed.
        Be sure to order new muffler bearing before you do anything else on the swap.
        • DesertBMW
          • Aug 2011
          • 1030
          I have to admit that there is no good M/S5* swap thread for noobs.
          for example http://www.r3vlimited.com/BOARD/showthread.php?t=147862
          What are the major basic required parts?
          Engine: m50, m52, s50, s52, complete with wire harness, ECU, accessories.
          E34 525i oil pan, oil pump, dipstick
          E36 engine mount arms
          E28 motor mounts
          E34 throttle cable
          E21 brake booster
          Problem is that person new to BMW will not know what E34,E28,E21 means, then will get more confused after buying oil pan from 1989 E34 525i and finding out that he has bought a wrong pan. Then go buys 1995 E36 318i mount arms and finds out that he bought wrong arms...etcetera.
          24v swap information that is available now is a mess
          • agent
            Vice Grand Pubaa
            • 7960
            There is a wealth of M/S5X swap information available on this forum if one is willing to put in just a little bit of effort reading.
            Same goes for the chassis designations. A quick trip to Google (likely ending up on Wikipedia) and some reading will result in the necessary knowledge. For pretty much anyone with high school level reading comprehension, that knowledge - combined with the research they've done on the subject - will parlay into deductive reasoning that they should be buying parts which fit the 24v engine they are swapping in, and not the same oil pan or mounts from a four cylinder.
            Originally posted by kronus
            • sweet3
              • Oct 2012
              • 751
              To actually answer your question...no you dont need to cut anything for the tranny. If you use a getrag, you will need a custom tranny mount bracket. If you use the ZF trans, then it should fit perfectly with original mounts and tranny bracket. I used the '89 325i trans bracket (I think they are all the same, but dont quote me on that.)
              The only headache with this swap was the brake booster. The intake manifold will need to be trimmed a little bit. I also drilled each hole for the brake booster 1/2 inch towards the fusebox. And then modified the clevis. (You can find a bunch of info on this by searching the forum.)
              I used original m20 trans mounts with the ZF trans. And I used the green e34 engine mounts with a 1/4 in spacer on top of the mounts.
              PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
              • spiDmang
                • 3941
                Seriously?! I did my first 24v swap years ago solely based on information thru this website. Anyone who doesnt know how to use search engines to find BASIC information regarding chassis designations probably shouldnt be tackling an engine swap.
                you make no sense.
                91' 318iS - S54/6MT Swapped
                08' E90 M3 6MT - Daily
                Originally posted by IronJoe
                Originally posted by 2mAn
                • e30_world
                  • Aug 2014
                  • 586
                  you make no sense.
                  This op is kid I think. He's posted a few really stupid topics. I'm guessing his first time on a forum. Either way. Has no business swapping anything, sell your car and buy a new one. Save us the classics.
                  F80 M3 Alpine
                  E10 Fjord Blue 2002
                  E28 Blackish 535i
                  E21 Silver 320i
                  Disco1 98 4.6
                  E30 Cirrus coupe S50 SOLD
                  E30 325i SOLD
                  E30 Alpine 325i vert Euro spec SOLD
                  E30 Alpine coupe 325is SOLD
                  • DesertBMW
                    • Aug 2011
                    • 1030
                    you make no sense.
                    Not everybody is smart as you and me and use real desktop computer with big screen to look for information. New generation of kids 16-20 use their small mobile device to look up everything. On that small screen they can't see much, browsing is a hassle. In fact written instructions are going out of style, people are too lazy to read, they want instructional video
                    • f4tj0n
                      • May 2013
                      • 411
                      l0lz
                      • 4tDX
                        • Jul 2014
                        • 507
                        • rturbo 930
                          • Dec 2005
                          • 2614
                          Do they still teach kids how to research in school these days?
