How bad are engine mount spacers?
  • Rugbyfan
    • Jun 2011
    • 286
    Even with condor motor mounts, one of my pipes running down from my TMS shorty headers is hitting my subframe. 1/4" spacer or BFH? What say you R3V?
    "Broke into the wrong God damn rec room, didn't ya you bastard!"
    • 34844
    I don't think a 1/4" spacer is going to change the engine angle very much. it's probably fine.
    • M3PO
      • May 2012
      • 537
      I put some pressure on it with a jack and heated the primaries with a torch to give me some clearance.
      • kronus
        • Apr 2008
        • 13032
        I cut a piece of square tube and used a slide hammer to clearance the subframe a bit. it worked as well. (for a 24v swap, but same deal..)
        cars beep boop
        • noid
          • 1537
          Should of just taken a hammer to the exhaust.
          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
          Your resource to tools and tips: www.rtstools.com
          • Rugbyfan
            • Jun 2011
            • 286
            I'm going to try the 1/4" spacers. Should I just do one side, or both?
            • ak-
              • 12422
              I would do both considering 24v pans hang low.
              Get some new mounts as well. Be mindful when you close your hood too lol.
              1991 325iS turbo
              • Northern
                I like cupcakes & sh!tboxes
                • 5284
                ^ I dented my hood using those fucking lencas mounts like 5 years ago - Engine hoist point and TB... Those fuckers were like 1.5x taller than stock ones. Since they were essentially a threaded rod with two aluminum discs sandwiching a polyurethane disc, I just made a thinner aluminum plate to bring it down enough to close the hood, and I ran it like that for ~4 years.
                When I pulled everything, the 25 year old guibo and CSB were still in good shape, so I don't buy the talk about messing driveline angle up with spacers.
                Originally posted by priapism
                Originally posted by shameson
