Grinding Gears in zf
  • NC325iC
    • Mar 2004
    • 6565
    It is a used one yeah, but I don't think that's the issue. I noticed it before when I had a single mass, it just wasn't as bad because of rubber bushings.
    Sent from my ONEPLUS A3000 using Tapatalk
    • NC325iC
      • Mar 2004
      • 6565
      Thats the one i bought, that is not the friction disc i am using I bought a new kit.
      • dude8383
        • Jan 2005
        • 10387
        Long shot but check your harmonic balancer.
        • pazi88
          • Sep 2015
          • 584
          Originally posted by NC325iC
          I am using a 328 driveshaft and an early model e30 CSB installed the only way it would fit.
          No you can instal it both ways. And the harder way that requires removing dust shield etc. is the correct one. Installing it wrong way will cause drive shaft vibration. And eventually it will jam the u-joint.
          • NC325iC
            • Mar 2004
            • 6565
            Can you get me pics of the proper way?
            I just remember when I was putting it on o tried to install it that way and the bushing part of the CSB was hitting the ujoint so it wouldn't turn.
            • NC325iC
              • Mar 2004
              • 6565
              ok just did a bit more research on it and I found the proper way to install it. It was always confusing. I will double check which way I have mine installed (need to double check my guibo install anyway).
              • Northern
                I like cupcakes & sh!tboxes
                • 5265
                the e30 CSB mounts in the tunnel are offset, so put the CSB on in the way that it corrects that offset.
                Lots of swap threads say to install it "backwards" but that exaggerates the offset so you end up with kink in the driveshaft:
                Push it 5mm forward when you tighten the bolts down when you install it, and you're golden. Pretty sure the only reason that's done is to hold the bearing in the rubber - there's a lip on one side only, so the preload stops it from backing out.
                Originally posted by priapism
                Originally posted by shameson
