Firewall DME Harness Grommet
  • nrubenstein
    • 3148
    I don't have a harness available to butcher (already butchered the harness I have, and I am NOT altering an S14 harness!), so I need another solution. Unless someone has one they can sell me, of course.
    So what other solutions are out there that don't involve altering the firewall? I'm dropping my spare S50US into the M3 to get it on the road until I have the time to rebuild the S14, so i'm especially uninterested in messing with the chassis.
    Has anyone ever found a part number?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • GG///M3
    • Dec 2004
    • 327
    I thought harness adapters were pnp no altering of anything? I'm in the same boat as you. About to drop in a s52
    • AllydNYC
      • Aug 2013
      • 350
      Also same boat. My harness was custom built but still no grommet. Really bugs me, a lot of wind noise.
      E30: '91 318is - M52/ZF320 | Azev A 16X7.5 | H&R Race/Bilstein | Completely refreshed suspension/brakes/drivetrain
      An Associate/Bachelors degree is America's most overrated product
      • nrubenstein
        • 3148
        Harness adapters have nothing to do with the firewall.
        • ForcedFirebird
          • Feb 2007
          • 8300
          I have to look at the storage over my office, but pretty sure I have a chopped m20 harness.
          Alternately, a swap we did a while back used an e34 m50 ECU box and set it on the battery tray, or could use a small plastic battery box.
          john@m20guru.com
          Links:
          • nrubenstein
            • 3148
            If you have got a damaged harness, I would *love* to buy the grommet, or the whole harness.
            • 2mAn
              Señior Mod
              • 20982
              Hmmm never thought of that. I have an E34 harness and the grommet is a major bitch that I havent really tried to get to fit into the enlarged hole in the firewall. I should actually try to get it through first, but thats not a bad backup plan. Not really a fan of having the ECU in the engine bay, but its also not ideal just sitting in the Glovebox... I have the 318-M42 ECU mount, but the wiring isnt quite long enough
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • GG///M3
                • Dec 2004
                • 327
                Would you mind posting some pics?
                • AllydNYC
                  • Aug 2013
                  • 350
                  A harness adapter connects the harness to the fuse box, the left side of the car where the fuse box is sitting.
                  The part that goes thru the firewall and into the glovebox is exclusively for the ECU, which you don't need an adapter for.
                  Sorry no pic, too lazy to edit one and then upload it.
                  • nrubenstein
                    • 3148
                    This. A harness adapter is located literally feet away.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      The m3 has the small hole in the firewall, like an early model, right?
                      john@m20guru.com
                      Links:
                      • GG///M3
                        • Dec 2004
                        • 327
                        Sucks in a forum like this it's so hard to find pics with decent info. Fail
                        • nrubenstein
                          • 3148
                          Normal round hole, same as any late model. Edit: IIRC, around 2" diameter.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            I have early and late model. I was on the understanding the m3 is based on the 1985 chassis, they have a smaller hole. When swapping in a late model (iS engine) into an early model, the hole has to be opened up.
                            Would be great if you could verify, I have them.
                            john@m20guru.com
                            Links:
                            • nrubenstein
                              • 3148
                              I'll measure it today to confirm 100%. I can tell you that I've confirmed that the M50/S50 DME plug fits through in the same manner as a late model. Electrically, the M3 has a standard round C101.
