Firewall DME Harness Grommet
  • ForcedFirebird
    • Feb 2007
    • 8300
    Originally posted by nrubenstein
    I'll measure it today to confirm 100%. I can tell you that I've confirmed that the M50/S50 DME plug fits through in the same manner as a late model. Electrically, the M3 has a standard round C101.
    The 24v dme plug is the same dimensions as the 318is, and similar width to the early model. The late model m20 connector is larger.
    john@m20guru.com
    Links:
    • nrubenstein
      • 3148
      Roughly a 55mm hole in mine.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Luke_M
        • Aug 2011
        • 275
        I used a cut M20 grommet but still had problems with water coming in the glovebox. I used some silicone and problem was solved. Probably not the best solution, especially with no grommet at all but it's has been fine for 3 years.
        Bonus: In theory it should clean up with no damage to the paint to should I ever pull it out.
        Euro S50 Daily Driver: http://www.r3vlimited.com/board/showthread.php?t=279195
        • ForcedFirebird
          • Feb 2007
          • 8300
          Can't cut them. Gotta pull the pins out of the ECU connector and feed the bare wires through.
          john@m20guru.com
          Links:
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            Ive got same issue. Toying with the idea of getting that expanding foam and just filling the hole with that but find a way to keep it nice and tidy. I mean really if you have completely rebuilt shit there shouldn't be a reason to ever remove it and it can easily be removed.
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • Northern
              I like cupcakes & sh!tboxes
              • 5237
              Mine was slit in half to get on the 24v harness, but now I also ripped a big piece off.
              I think some sort of generic grommet is the way to go.
              Thinking about something like this:
              McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
              I would anticipate modification, which seems like a lot for ~$20.
              Otherwise maybe stacking two sizes of these:
              Originally posted by priapism
              Originally posted by shameson
              • ba114
                • Sep 2015
                • 364
                I'm looking at expanding foam too as i currently dont have anything and dont fancy water running down the wires into the dme...
                RHD OBD2 M50b25 turbo build thread:
                http://www.r3vlimited.com/board/showthread.php?t=384800
                • Klug
                  • Sep 2011
                  • 804
                  I'd really be interested in seeing that e34 m50 DME box setup in the front.
                  I ended up cutting a m20 grommet, slid it over the harness then silicone'd it in with no issues. Granted I used that e36 or whatever firewall cover to cover it all up.
                  555Garage - Kingston, PA
                  '13 BMW e70 X5 35d
                  '95 BMW e34 525i
                  '92 BMW e30 325i S52 Vert (Quade the Vert)
                  '92 Range Rover Classic
                  '90 Range Rover Classic
                  '89 BMW e30 325i Coupe (The DIRTY30)
                  '81 VW MK1 Rabbit Caddy Diesel
                  '76 Honda CB550K Cafe/Brat
                  '67 Pontiac LeMans
                  '24 Model T Depot Hack
                  ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
                  • AllydNYC
                    • Aug 2013
                    • 350
                    I'm still in need of a M20 grommet. Anyone?
                    E30: '91 318is - M52/ZF320 | Azev A 16X7.5 | H&R Race/Bilstein | Completely refreshed suspension/brakes/drivetrain
                    An Associate/Bachelors degree is America's most overrated product
                    • Codym42
                      • Mar 2013
                      • 611
                      Is this what you guys are looking for? 51711972464 is the 52 mm grommet. Double check this diagram:
                      http://www.realoem.com/bmw/enUS/show...diagId=41_0167
                      I had considered buying a new one. But, at $24, I just cut a slit that came from the one in my m42 powered car. I also have an m3 firewall cover to go on. Hopefully water and wind noise doesn't come in.
                      '90 325i - 5 speed coupe
                      '05 330ci 6MT ZHP
                      • drum4fun27302
                        • Mar 2019
                        • 18
                        Maybe this would work?
