is a m50 swap worth it?
  • cahomey
    • Mar 2004
    • 1201
    #76
    So is the m50 swap worth it?
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
    • FredK
      • 14761
      #77
      Yeah, you can buy the paint at any auto store. Duplicolor and VHT both make krinkle finish paint.
      • BDSax
        Junkyard King
        • Mar 2006
        • 3594
        #78
        update, next is putting on the intake manifold!
        im unsure on the position of the motor mount arms.
        also not sure how the oil dip stick tube gets mounted. anyone have an pictures???
        • 325Projectz
          • Jan 2005
          • 1956
          #79
          Your motor mounts look correct. Your dipstick should connect to a intake manifold support bracket, if not, make one, takes like 5 mins if you are crafty to make it look good.
          91 m3
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            #80
            sweet, now another question is where does the intake brackets mount? i thought maybe on the bolts that hold the motor mount arms
            • 325Projectz
              • Jan 2005
              • 1956
              #81
              You can see where I circled it.
              91 m3
              • BDSax
                Junkyard King
                • Mar 2006
                • 3594
                #82
                i started cleaning up my intake manifold today, noticed the temp sensor, does that need to be a e30 temp sensor?
                i changed the one on the head, the e30 temp sensor is 1 pin and the e36 is 2, is this right??
                • Erick
                  Official R3V Drifter
                  • 11169
                  #83
                  it depends.... the e30 has 2 temp sensors -.-'
                  ..::Support FullOpp::..
                  FullOpp Stickers for sale!
                  Feedback Thread
                  • FredK
                    • 14761
                    #84
                    whoops, I didn't read the original question correctly. No, use the IAT sensor that was already installed in the intake manifold.
                    For the head, you replace the rear black sensor with the E30's brown one pin temperature sender.
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      #85
                      Originally posted by FredK
                      use the one pin brown sensor from the E30 to replace the black E36 sensor
                      Orly?
                      Damn I grabbed a blue one!!!!!
                      Originally posted by 325Projectz
                      don't listen to the diagram... listen to mr. swiss.
                      :nice:
                      • BDSax
                        Junkyard King
                        • Mar 2006
                        • 3594
                        #86
                        sweet, getting closer and closer, now these coolant hoses are confusing me
                        • e30devo
                          • Aug 2005
                          • 1102
                          #87
                          holy shit sax. that motor looks amazing. i appreciate when people post pictures and stuff.. makes threads nice to read. good fucking work man.
                          • BDSax
                            Junkyard King
                            • Mar 2006
                            • 3594
                            #88
                            thanks for the kind words
                            • Jean
                              • 18228
                              #89
                              Good job man, I am going to be doing this soon also.
                              • B3M2W5
                                • 283
                                #90
                                I kinda like it
                                This is what i did with my mine.
                                Although there is alot more then just aluminum polish, started with a penut grinder and went form 120 girt to 400 girt sand paper, then rubbing compund with steel woll and then a plain rag, best with an old wash cloth, and finaly as much aluminum polish as you want, or untill you arm gets tired
