Has anyone ever tried the E39 528i thermostat housing?
  • Daeldalus
    • Nov 2012
    • 304
    I was looking today at a 97 528i and the thermostat housing has a bleeder built in. Seems to me that might make bleeding these swaps 12x easier. Anyone ever tried it?
  • e30davie
    • Apr 2016
    • 1788
    Assuming you are talking about the m20 I've never had an issue bleeding mine.
    Edit. Sorry just realised what forum this was on. I just always press "new content"...
    • Daeldalus
      • Nov 2012
      • 304
      M52 swap. This is the 24v swap sub forum.
      The traditional way of doing this swap is with e30 radiator and e36 thermostat housing. Which means you have no bleeder anywhere in the system.
      This seems like an easy fix to that.
      • reelizmpro
        • 9559
        Hadn't noticed this. I just tossed one away too. Good thing new aluminum replacements are cheap. I think I bought a Uro one for less than $20.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • kronus
          • Apr 2008
          • 13032
          the overflow tank?
          anyway, a lot of people end up using e36 radiators for these swaps and those have bleed screws.
          cars beep boop
          • Daeldalus
            • Nov 2012
            • 304
            ^ in theory the overflow tank should be self bleeding.
            In actual practice it only starts to self bleed after you have bled about 95% of the air out already.
            One thing I noted today is that the hose that I used on my swap and that many other people use will not work for the e39 housing because the hose bottlenecks right after the end that goes on a normal e36 thermostat housing.
            An e39 hose may work. Will have to do some research.
