e34 525i Oil Pan
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    i used the e36 tube with the e34 stick
    • etxxz
      • Feb 2006
      • 2085
      ^^ ahhh gotcha...then still as long as it measures correctly or have some kind of hussler under the table understanding with your dipstick
      No more e30s for me.
      88 black BMW OBDII 332is dedicated track [sold]
      88 BMW OBDII bronzit 332is [RIP 03/08]
      91 BMW 325i [sold]
      86 Corolla 'Ae86' HB 20v trd [sold]
      http://youtube.com/watch?v=pTj7Hn9v5Rs
      • Jason89i
        • Sep 2004
        • 875
        e36 has 2 different dipstick tubes. obd2 is larger in diam and has oil recovery drain from seperator. e34 tube (i think sticks too) are a different length than the e36 ones. use the e34 tidbits or your oil reading will be off.
        cheers, jason
        • hoveringuy
          • Dec 2005
          • 2745
          I just did a side by side...
          The E-34 tube and dipstick are slightly shorter than the E-36 counterpart. Same diameter for OBD1
          However, they are a matched set. Shorter tube, shorter dipstick. They reference to the same position relative to the block/pan joint.
          I don't see any reason why the E-36 set wouldn't work as long as the stick and tube are used together.
          • shalashaska1985
            • Oct 2007
            • 1
            hi guys,
            I am also performing the M50 swap into my E30, and i bought the 525i oil pan. When i removed the original one there was the oil pump pickup line that extends to the end og the block, since the oil summin is at the back, and the 525i oil pan summin is at the front.
            can this pick up line be changed????
            i saw the posts before but i need to make sure, and it would be really helpfull to describe the actuall procedure.
            Thnx alot guys, u've been really helpfull :D
            • tonytony
              Knee deep in poopie
              • Jan 2004
              • 3498
              yes just change the pickup to the 525 one ie: the shorter one
              • Jason89i
                • Sep 2004
                • 875
                Originally posted by shalashaska1985
                hi guys,
                ............. When i removed the original one there was the oil pump pickup line that extends to the end og the block,...........can this pick up line be changed????
                read post 2
                Originally posted by FredK
                You need the oil pickup tube which is attached to the pump with 2x M6 bolts. .....
                or page 1 of the comprehensive dohc thread stickied on this forum.
                • EtaSport
                  • 2853
                  Originally posted by tonytony
                  i was using an e36 dipstick in my e34pan worked great, i prefer it over the e34 pan. I had two side by side and tried both of them out and sold the e34 dipstick
                  werd.. ive had them both in the pan too.
                  Old and improved:
