I have an 88 with a solid s52 in it.
Stewart water pump
triple core radiator from the M Roadster
low temp t-stat
Two 8 inch pullers (Be Cool fans)With a custom shroud
13 row oil cooler with the oil cooler adapter
Digital gauge measuring water temp, oil temp, and oil pressure
Driving back from LA to the Bay Are California, 90 degree weather, car starts to overheat as I pull up to the driveway. 244 degrees! The entire drive the car was at 183 - 196 degrees. When I got off the freeway, it got to 201. 20 blocks later pulling up to the driveway, 215 degress, then all of a sudden 244 degrees!
WTF! How can I keep this car cool and keep it from overheating? I have all the stuff I can think of to make it cool other than a vented hood. Ideas?
I think there is still air in the system but I have burped it like 8+ times. Should I do a leakdown at this point?
Stewart water pump
low temp t-stat
