735i brake booster/cylinder
  • Ray Smoodiver
    • Jun 2004
    • 8809
    #31
    Originally posted by MR 325
    E23 is hyrdoboost or whatever they call it. E23 won't work.
    Uh, what? Sure it will, just works in a different way :p
    And its a much prefered setup for Euro S50 swaps
    • BigD
      • Jul 2006
      • 1085
      #32
      Originally posted by chuck90m3
      you wont have enough threads to adjust it down far enough. or just buy the right shit, its a $7 part. not the biggest expense the swap.
      Yes you will. I've done it on my car, my friend who is a mechanic has done probably a few dozen. Don't overcomplicate the simple shit and confuse people trying to figure this out. There's enough of that on this forum as is.
      • etxxz
        • Feb 2006
        • 2085
        #33
        ^^ i am etxx and i approve of that message ^^
        i too did it, it works, it even has plenty of threads for adjustment.
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
        • moatilliatta
          • 6138
          #34
          e34m5
          MC http://www.realoem.com/bmw/showparts...16&hg=34&fg=25
          e32 735
          MChttp://www.realoem.com/bmw/showparts...94&hg=34&fg=25
          BB http://www.realoem.com/bmw/showparts...86&hg=34&fg=25
          e30 ix
          MChttp://www.realoem.com/bmw/showparts...21&hg=34&fg=25
          BB http://www.realoem.com/bmw/showparts...03&hg=34&fg=25
          @Zakspeed_US
          • mightywhitey
            • Oct 2009
            • 985
            #35
            The above post is awesome and helped me spend my money wisely. Bump for the search button.
            1991 e30 328i M52 swapped: Gone
            1995 e34 540i/6 1 of 76 Clean
            1985 e28 euro 525i the daily
            • glucklich21
              • 1912
              #36
              We were discussing MC's not too long ago on E30tech. The E36 M3 is also compatible.
              • Mr.SWISS
                • Nov 2005
                • 1251
                #37
                My POINT is that the E30 fork and the IX fork are different pieces. If you use the 7ser or the regular E30 forks your brakes will not work properly. I am not saying they will not perform optimality, they will actually lock up while driving the car. The 7ser and the regular E30 forks are longer and you can not get the correct amount of adjustment out of them. which in turn will keep the brakes slightly ingaged and cause the ABS pump to lock up either the front drivers side or the rear passenger side of the car. I know this from experience, trust me.
                If you have access to a tap and die set you can run the threads through the 7ser or E30 fork and shorten the back side to an overall length of 40MM. Or just order PN 35 21 1 158 439, i want to say they are $5-$10 with no work.
                ^ This is a crock of shit.
                Just installed my 735iL booster/master out of a 90 e32. All that was needed was bending the lines to meet and swapping out the clevis from my original e30 booster (89325is). Result was actually pedal lower than the clutch and did not actuate the brake light switch, a few turns on the shaft and tighten the nut and viola! Done. The hose doesn't quite reach but I am going to use a tii remote res anyway phuck it 2 tears in the bucket.
                8-)
                Originally posted by 325Projectz
                don't listen to the diagram... listen to mr. swiss.
                :nice:
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  #38
                  I liked the lower pedal postion, I actually bent the brake light switch bracket down so I could keep the brake pedal closer to the gas pedal, mad tyte heel toe yo!
                  '89 Alpine S52 with goodies
