how fast is an e30 with m50???
  • Lost
    • Jan 2008
    • 10
    Originally posted by rThor432
    Just put a DA super charger on your car for now. With that it will keep up with E36 M3's anyway. I believe GRM's car dynoed at 200 whp with the DA setup. Stock S5x's put down around 210 iirc.
    S5x or no DOHC. M5x just seems half-assed. For the cost of an M5x swap you could have a hell of an M20.
    If it's not hard, maybe you know the price for DA super charger kit for 318is?
    If I swap m50 in my car price is the following:
    -engine 700$
    -m20 clutch 160$
    -e36 driveshaft 40$
    -differential 3.73LSD 400$
    -other stuff 200$
    -exhaust 200$
    I will stick with getrag 240.
    Totally around 2k$ + I get something back for my m42. (around 500$)
    If I go m52 route, around extra 600$ for engine.
    Both ways I get 192hp and with m52 more tq.
    Any opinions?
    :D
    • e30polak
      • 6136
      add a turbo or super charger to that list :D
      INSTAGRAM: @UNDR8D_EMPIRE
      • 02stu
        • Jan 2005
        • 872
        I originally had an m50 and didn't think it was all that fast. The m52 was a huge improvement.
        • turboeta
          • Aug 2007
          • 571
          My M50 swap is gonna end up costing me about $1500, but that will be a freshened up motor with ALL new gaskets. My turbo setup when complete will run me about $4500. So $6000 dollars, and about 450rwhp. In my opinion if you plan to go FI in the future, save the money and get the M50. You can always throw a different crank in it and have a 2.9l. I still wish I bought a non-vanos motor though :(
          635csi Euro/Alpina B7S
          • e30polak
            • 6136
            exactly for pure power reasons, m50 NV+ FI= WIN!
            • Lost
              • Jan 2008
              • 10
              Yes I found that supercharger will run around 3.3$, and you will get 200hp form m42, and you won't actually have next step to do.
              M50 swap will run around 2k - m42engine and you will have next step:)
              Why m50 NV is better that vanos engine?
              And that are differences in fuel consumption?
              I am planning to build my car as daily driver for now, that's why fuel consumption matters:)
              • turboeta
                • Aug 2007
                • 571
                Yeah, beefier rods, dual valve springs, and different cams. NV FTW
                • turboeta
                  • Aug 2007
                  • 571
                  Stay away from superchargers anyhow, if you do it...do it right.
                  • PiercedE30
                    • Apr 2005
                    • 4220
                    Beefier rods = HEAVIER rods. That's the reason I didn't use them in my build. I used the M52 rods, since they are forged, the same length, and lighter.
                    My 2.9L Build!
                    • turboeta
                      • Aug 2007
                      • 571
                      Also true, but the weight won't play a hufe factor when you're boosting 21psi :razz:
                      • rThor432
                        • Feb 2007
                        • 3907
                        Originally posted by Lost
                        Any opinions?
                        :D
                        An M50 is just a waste. I dont care if it is $700, it doesnt have enough power to overcome the added weight. For the cost of the motor alone you could build up a decent M20 that will easily out run an M5x.
                        If you do it right you will have more than $2k in it. Not saying you cant do it for that, but if I had an engine out it would be fully refreshed and decently hot rodded before it went back in. Not to mention I would buy a new lighter flywheel, clutch, and pressure plate that would run an extra ~$800 anyway.
                        Just get an S50 or S52 [unless you build an aluminum block]. Even then, I would put money into it so that it would out-perform an ///M motor.
                        My opinion though.
                        • matt
                          • 3732
                          A lot of you guys need to learn some stuff for yourselves and ignore the internet BS that goes around.
                          • matt
                            • 3732
                            Did you skip the non-vanos pistons also?
                            (My last post doesn't apply to you)
                            • hoveringuy
                              • Dec 2005
                              • 2744
                              For the record, I like my M50.
                              I liked my M20, too (but not as much).
                              Not everyone does the swap to run a 14 second 1/4.
                              • matt
                                • 3732
                                My NA e30/M50 was a lot of fun also, for the record.
