The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • Wishno87
    • 6025
    #1081
    Originally posted by Matt-B
    Josh, what goes in 2nd hole of intake boot?
    I know 1 hole is for the ICV to boot hose, and the other hole is for Valve cover to boot?
    Yup other goes to the VC though that little pipe attached to the dip stick tube I think and then to the VC.
    • Matt-B
      The Waffler
      • 3856
      #1082
      Yea, I just need that fitting that goes from a small hose to big hose.
      Thanks man, can I pick your brain tomorrow? Or come down and make some notes?
      • Wishno87
        • 6025
        #1083
        Ya sure. I think Im going to have the day off.
        • Matt-B
          The Waffler
          • 3856
          #1084
          want to look at your vacuum routing and etc and starter wires etc thanks buddy, call you about 10 or so AM
          • drumad
            • Aug 2009
            • 1700
            #1085
            Hopefully you and the other guy would do this for me, but can I get pictures? I took pictures of my routing before I took it all apart but I'd like to see a completed swap set up.
            (Yes, I know alot of shit can be in the way, but who knows.)
            2008 335i - n54b30
            1991 318i - m52b28
            1994 fzj80 - LAND CRUSHER
            • Matt-B
              The Waffler
              • 3856
              #1086
              ill get pics soon
              my new parts are on the way
              got it figured out....
              • drumad
                • Aug 2009
                • 1700
                #1087
                Sweet. I appreciate it.
                2008 335i - n54b30
                1991 318i - m52b28
                • Jand3rson
                  • 37587
                  #1088
                  Hay guise... I've got these 2 brackets that I'm trying to get installed on my M50, and I cannot figure out where they go. They look like they're both for hoses, but I can't figure out how they mount. Someone mind filling me in, or snapping a pic?
                  • Matt-B
                    The Waffler
                    • 3856
                    #1089
                    grabbing pics now...
                    • Van Westervelt
                      • 9365
                      #1090
                      both go under the intake. the upper one is on the back and holds the fuel lines, the other is actually bolted to the dipstick tube I believe.
                      You can see the fuel lines and bracket in this pic of my original s50
                      • Matt-B
                        The Waffler
                        • 3856
                        #1091
                        the smaller bracket is designed for holding... Im not sure, but it goes between intake bracket and the small slot goes on the bottom fin of intake
                        One you see the 2nd pic, you can see it fits nice an snug in there
                        Other bracket, kinda the same deal, holds a heater hose i guess, but Mine wont reach
                        the end of the bracket shaped like this UU holds the fuels lines and need to be turned to make them run horizontal ish..
                        Hope that helps Josh, its cold outside
                        • Van Westervelt
                          • 9365
                          #1092
                          That smaller bracket holds the crank case vent tubes from the front corner of the valve cover.
                          • Jand3rson
                            • 37587
                            #1093
                            Awesome, thanks fellers.
                            • Matt-B
                              The Waffler
                              • 3856
                              #1094
                              What can you guys tell me about fine tooth and large tooth flywheels?
                              I have a fin tooth it looks like and the big tooth starters don't work right?
                              • Jand3rson
                                • 37587
                                #1095
                                Aight, time for another round of "where does this go"? :D
                                1. Plugs into the valve cover, at the front near the end of the fuel rail.
                                2. Plugs into the inlet of the hose connector that's on the E34 dipstick, right?
                                3. ?
                                4. ?
                                Part II of #2: Where does the hose go that plugs into the other end of the hose connector on the dipstick?
