The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • Vtec?lol
    • Dec 2009
    • 3278
    #1066
    • Jand3rson
      • 37587
      #1067
      It looks like I have a lot more put together than I thought I did, I don't really have that much left to bolt up. RealOEM has been a big help, tho.
      • spider2077
        • Nov 2008
        • 8
        #1068
        need some help with my m52 swap,
        I am down to the wireing, but I have a small problem I am keeping the EWSII for $$$ reasons, I wired up the engine but the EWS is still not working been over the wires 4 times, every thing seems to be in order but still no crank.
        here is how I wired it
        Main EWS II 61.35-4 4 146 047
        1 BLK/Yellow to starter
        2 White/purple to it's brother on the connector
        3 blk/green to the ignition key
        4 green to DME
        5 red/ yellow to continus 12V
        6 none
        7 brown to ground
        12 black to pin 20 on the connector also black
        13 light blue to transmiter
        I am left with 8 black/green - ?
        14 blue/red/yellow - ???
        12 Black - ??? speed input I think
        EWS transmiter
        1 to 13 on the main EWS
        2 to +12V acc on
        3 to ground
        Please help cant seem to start the car tryed every thing that I can think of
        • Jand3rson
          • 37587
          #1069
          So what are you people using for an 02 sensor? Is anyone using the Bosch Mustang sensor?
          • Wishno87
            • 6025
            #1070
            I just got a new bosch for an e34 for around 75 shipped.
            • Jand3rson
              • 37587
              #1071
              The Bosch Mustang 02 sensor for the M20 is about $35, and all you have to do is splice the wires. I'm just curious if it works on the M50.
              • Danny
                • 14217
                #1072
                If it works on the m20 it'll work on the m50. I used the stock e30 sensor.
                • Jand3rson
                  • 37587
                  #1073
                  Then that's what I'm doing. $35 vs. $75 or more is no question.
                  • phreshkid
                    • 4655
                    #1074
                    I just ran full obd1 m3 midpipe and m3 muffler. It did the job.
                    • Jand3rson
                      • 37587
                      #1075
                      Where does this mount? It looks like it bolts to one of the intake manifold brackets, but which one, where, and what does it go to?
                      • Wishno87
                        • 6025
                        #1076
                        When I got my engine it was bolted to the block a little to the right of where you are holding it but not on the mount arm bolts. Also your rear intake manifold bracket pictured there needs to be replaced with a E36 part if you want to run both brackets and not just the front one. The E36 part bolts to the extra hole on your E36 mount arms.
                        • Jand3rson
                          • 37587
                          #1077
                          New random question time!
                          Using a Getrag 260 with an M20 fly, do I still need the shim plate that goes between the flywheel and the flywheel bolts? #10 in this pic:
                          • Matt-B
                            The Waffler
                            • 3856
                            #1078
                            yea same question here...
                            • Wishno87
                              • 6025
                              #1079
                              I would install it. It is there to put even pressure on the FW no?
                              • Matt-B
                                The Waffler
                                • 3856
                                #1080
                                Josh, what goes in 2nd hole of intake boot?
                                I know 1 hole is for the ICV to boot hose, and the other hole is for Valve cover to boot?
