The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • exhaust
    • Jun 2015
    • 411
    #1366
    Answering question 2:
    The ZF from the E34 will mount up normally. You'll just need to do the additional steps of the manual swap. Pedals/etc.
    • trout
      • May 2014
      • 33
      #1367
      question: can i use the quad exhaust from the z3m donor when i do my s52 swap? i'm mostly interested in passing smog. i figure the fewer mods i have to do to the exhaust the better
      i've searched for any reference to this and couldnt find anything. maybe i overlooked it, or maybe i'm just the first one dumb enough to try it, haha
      • JRKOUPE
        • Dec 2004
        • 3159
        #1368
        I don't recall any 1 ever trying this...
        unless this is your dream set up...its not needed...
        its was done this way to fit the z coupe chassis..not smog
        use 1 or 2 mufflers, and a cat if needed....and that's it
        • Zesty Bonanza
          • Apr 2011
          • 88
          #1369
          Is the IX booster supposed to fit without modification? I bought an IX booster (not sure if it's from an actual IX but it is a dual diaphragm) from a forum member but the bolt pattern is different than the firewall and the shaft is too long.
          • thexfactord22
            • Aug 2012
            • 37
            #1370
            Hey guys, I had a quick question. I been searching all over but cant find the anwser. If your are doing an OBD1 enngine swap, do you need to keep the chorcal cannister? Or do I need to use an e36 one, so it plugs into the harness?
            • bradmer
              • May 2016
              • 389
              #1371
              I am using the cats from the donor z3m car in their original location and an aftermarket muffler. Going in to the BAR referee soon to get the sticker. The engine is really quiet :(
              • trout
                • May 2014
                • 33
                #1372
                let me know how it goes (or went) with the ref.
                i'm probably gonna delete the spare wheel well and battery tray to keep the quad exhaust. i'll just get a emergency spare to fit in the trunk and move the battery up closer to the rear seat.
                • 2mAn
                  Señior Mod
                  • 21049
                  #1373
                  The general rule of thumb is to use all the emissions equipment from the donor car/ engine. Are you aiming to BAR it as an OBD2 car?
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • trout
                    • May 2014
                    • 33
                    #1374
                    yes, full obd2
                    • Dice_980
                      • Apr 2015
                      • 10
                      #1375
                      Hey guys I want to swap an S50 to replace my M42 engine. After reading through all these pages and googling for some other info I have come up with this part list wanting to see if I am missing anything.
                      • S50 Motor
                      • Red Labeled 413 ECU w/ all other accessories & engine harness
                      • Garagistic harness adapter
                      • 6 Cylinder coding plug for my Tach
                      • E36 Motor Mounts w/ e28 Green Motor Mounts
                      • e34 Oil pan, oil pump, and pickup arm
                      • M20 Temp Sensor
                      • A/C - Larger hose I can use my original one. Smaller one need to have the side connecting to the compressor changed to an E36.
                      • Porsche 944 ATE Booster threads shortened w/ stock MC
                      • Can use original Radiator w/ attached overflow tank
                      • E34 Throttle Cable
                      • 260 Tranny w/ garagistic trans mount
                      • M20 driveshaft w/ shiftlinkage cut and turned or cut and weld to make centered
                      • 3.73 LSD
                      • M20 Starter
                      Good cats and exhaust w/ canister I should get my tags?
                      What type of flywheel should I use?
                      I have to shave the engine side of the flywheel correct?
                      What type of fan should I should? Or do i use M20 fan and clutch?
                      Are my stock powersteering hoses fine I also have e36 Z3 rack installed is that a problem?
                      • wworm
                        • Dec 2016
                        • 1719
                        #1376
                        ive got an 87 325 (eta) and im swapping in a 96 m52b28 with the zf320 trans. Can I use the stock radiator and overflow? which shifter linkage will I need to use?
                        1984 Delphin 318i 2 door
                        • mtech325
                          • May 2008
                          • 569
                          #1377
                          Technically you could use it, but the way the spider hose or coolant pipe for the m52 exits the block works a lot better with a late model m20 expansion tank since both sit on the driver's side of the car (You'll also want the late model m20/e36 6-cylinder radiator too). Otherwise you would have to run a long hose all the way back to passenger side where the pre-88 expansion tanks sit.
                          As for the shift linkage, you'll want to use the carrier and selector rod from an e36 m3 or e36 328.
                          • wworm
                            • Dec 2016
                            • 1719
                            #1378
                            thanks bro!
                            • UgkNW*
                              • Oct 2013
                              • 259
                              #1379
                              Question. Would cutting the extra wiring connectors from my my s52 harness and heat skrinking them be a bad idea? Connectors like sap, rear o2 etc..
                              I want to cleanup the harness of unnecessary connectors I won't be using.
                              • Metallated
                                • Dec 2016
                                • 1074
                                #1380
                                I think that would be a great idea.
                                I also have a quick question. I've done some reading and know I need to rethread the brown top temp sensor but I haven't been able to find the exact thread. Anyone know what they've used successfully?
