The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • amcp
    • 489
    #1396
    I believe the flywheel rubs the block if you dont.
    • schmidty
      • 1253
      #1397
      Yeah, it won't fit if you don't. At least not when using the g260
      Sent from my Pixel 3 using Tapatalk
      • 968Reckless
        • May 2013
        • 1095
        #1398
        Originally posted by Panici
        Amazing, thank you!
        Parts list would be great for reference.
        Absolutely necessary to shave down the m20 single mass flywheel? What happens if you skip this?
        Mock everything up and you will see the problem.
        /// MTech Belts ///
        S52 BUILD
        M3 VERT BUILD
        • fastestbox
          • Jul 2018
          • 124
          #1399
          Anyone have any experience with fitting a Z3 exhaust manifold on an e30?
          91 318iS - aluminum M52B28 + ZF320 + 3.15 Torsen
          • e30strokr
            • 211
            #1400
            so I go a SETA 88 325 (e?) with G260 transmission which I believe has the dual mass FW.... is it safe to use or should I be looking into getting a 325I Flywheel?
            • chilone
              • Oct 2021
              • 1
              #1401
              Hello everyone. My first post! I'm sorry if this has been covered bet there's SO much to sift through. My daughter and I are doing a M50 swap in a 1991 318is with a G240 gearbox in it. I see a lot of talk about G260s but can we use the G240?
              Thanks.
              • TeXJ
                • 1914
                #1402
                Thanks.
                first response:
                http://​​​​​​​https://www.r3vlimited.com/board/forum/e30-technical-forums/24v-engine-swaps/m50-52-s50-52/215116-m50-with-a-g240
                1990 325is
                m52b28
                3.73lsd
                g260 (1987 325is 5spd tranny)
                • dylhaus
                  • Aug 2021
                  • 89
                  #1403
                  In regards to using the single mass m20 flywheel with the G260 trans on a S50 swap, when shaving it down, is it best to just shave down the area hitting the rear main seal bolts, or should I just take down the whole back side a few mms and re balance?
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5265
                    #1404
                    I'd say if you're already paying for the bulk of the setup/balance work, you may as well get the thing lightened.
                    Originally posted by priapism
                    Originally posted by shameson
                    • dylhaus
                      • Aug 2021
                      • 89
                      #1405
                      I think I might've lucked out with the flywheel I bought. It's the E21 323i lightweight M20 flywheel 11221264517 that is all ready missing the ring on the back that the normal M20 flywheel has (which I assume is the part that needs to be machined down in the first place since the back is nearly flush with the ring gear). We'll see if the starter on the ix M20 will work I guess. Anyone know if I need to get a euro 323i starter to match that flywheel?
                      • mjweimer
                        • Dec 2015
                        • 648
                        #1406
                        If my memory is correct, the E21 and E30 M20 flywheels have the same ring gear tooth count/profile. The E30 starter is half the weight and smaller than the E21 starter so several folks have done that swap as an upgrade when rebuilding their engine. I think you are good to go.
                        • dineshblack
                          • Mar 2025
                          • 1
                          #1407
                          Hi ALL!
                          Hoping this board is still active.
                          What I have,
                          1990 BMW e34 520i, M50b20 NV.
                          What I have done
                          Complete M50b25TU swap with harness, ECU and meter.
                          Car cranks but does not start.
                          Theres fuel through the injectors, theres spark, compression is good.
                          Have no clue what else to diagnose as all the sensors have been changed. Could there be a wiring issue I am missing? all grounds checked.
