What would you have differently, knowing what you know now??
  • trackjunkie21
    • Jan 2010
    • 3962
    #31
    Should have gone s50/m60 from the get go.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • gobuffs
      • Dec 2004
      • 513
      #32
      I shoulda just bought a GT3...would have be cheaper and easier.
      • lbreevesii
        • Aug 2009
        • 412
        #33
        I'm not done yet.. but I wish i had realized how far along obdII has come, I might would have S54'd instead of S50'd.. Then again i did get my S50 for a song.
        My real head bashing comes from putting time and money into parts that I'm ending up replacing or removing completely now that i'm swapping(M42 seals, shifter front delrin bushings, new small guibo and csb for the E30 shat that i'm now ditching, etc)
        I don't always wreck cars, but when I do I wreck them into trees.
        91' 318is S50 swap - The Black Widow
        • gp.plus
          • 416
          #34
          Originally posted by lolcantturn
          Did you use a new gasket? I used a new Victor Reinz gasket and it still leaked! Put RTV along with it and it worked fine....the quality of these gaskets suck!
          Same deal, block and pan surfaces cleaned to perfection, new Vic rein gasket... Torqued/sequenced the bolts, got a slow drip front right corner. Gonna pull the motor back out in the spring and re-seal it w/rtv.
          • Adrian_Visser
            • Jun 2006
            • 2823
            #35
            Fuck me too! Godamn brand new gasket and it leaks like hell. Top that off with the fact I'm running a G260 so I have to pull the tranny just to drop the oil pan,
            '89 Alpine S52 with goodies
            • burkey001
              • Feb 2011
              • 608
              #36
              Not actually a silly idea. An ex-race 997 or 996 GT3 isn't as expensive as you'd think.
              Goes and stops a bit better too... but is it as fun??? Well maybe
              88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
              90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
              • scottinAZ
                • Dec 2009
                • 1312
                #37
                I would have done my swap right off, and not tried to save the M20 that was in the car. Would have also done the ZF trans with new clutch first and not cobbled together a bunch of old G260's and associated parts.
                I saved 15% on my Bimmer parts by switching to ...
                • lolcantturn
                  • 4588
                  #38
                  With a "trusted" name like victor reinz you would think they would put a bit more quality in a gasket that could only be changed basically when the motor's out...very annoying shit.
                  Originally posted by TSI
                  OEM+
                  • lbreevesii
                    • Aug 2009
                    • 412
                    #39
                    you guys and your gasket leaks are starting to scare me. My motor is still out of the car though, so mayybe i should rtv it...
                    • lolcantturn
                      • 4588
                      #40
                      Do it. I wouldn't trust it one bit. Every VR gasket i've used NEW, has leaked. Valve cover, thermostat housing, oil pan gasket, spark plug gaskets, all of them. I've cleaned the surface throughly and they're all straight.
                      OEM+
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        #41
                        Use a lift, and drop the old engine on the subframe, then put the new engine in on the subframe from the bottom.
                        • drumad
                          • Aug 2009
                          • 1700
                          #42
                          Removed the firewall rubber molding.
                          My harness barely has any room around the intake manifold area.
                          2008 335i - n54b30
                          1991 318i - m52b28
                          1994 fzj80 - LAND CRUSHER
                          • etxxz
                            • Feb 2006
                            • 2085
                            #43
                            ^^+11000213!!
                            they seal very well in my motor. Just make sure your surfaces are nice smooth and clean... and flat. If they are distorded is not the gasket's fault. I did goop up both sides of the oil pan gasket for safety.
                            No more e30s for me.
                            88 black BMW OBDII 332is dedicated track [sold]
                            88 BMW OBDII bronzit 332is [RIP 03/08]
                            91 BMW 325i [sold]
                            86 Corolla 'Ae86' HB 20v trd [sold]
                            http://youtube.com/watch?v=pTj7Hn9v5Rs
                            • N2MYE30
                              • Oct 2007
                              • 5536
                              #44
                              To be really picky, I would have replaced the intake seals. I may have relocated my booster too. All in all, I was prepared. It was 3 months of searching for parts and researching on all websites. Two weeks from running M20 to running M50.
                              I wasnt prepared for the exhaust price but in the end, I am happy with my final results.
                              COTM
                              • eandrade
                                • Jan 2007
                                • 117
                                #45
                                What would I have done differently?
                                • Performed a detailed inspection on every single used part that I purchased from various other people.
                                • Purchased brand new knock sensors (the piece of mind is worth the couple of hundred bucks)
                                • Double checked that the @!*^&%~!# CPS wire was routed properly and not rubbing against the water pump pulley where it would end up shorting against the block and causing 5 AAA tows and countless parts replaced trying to chase down an intermittent misfire/no start that would ONLY appear when you were at least 10 miles away from home. Argh.
                                • Invested the money on learning how to weld properly (custom exhausts are expensive!)
                                • Removed all that rubber/foam insulation on the firewall.
                                • Cleaned my engine bay.
                                • Remembered to disconnect that !~^%$~!# clutch line from the transmission before trying to pull the motor.
                                • Spent the extra time locating the parts that I REALLY wanted instead of going with a stop gap solution to hold me over (e.g. 3.46 diff instead of 3.73, Eisenmann exhaust instead of Magnaflow)
                                • Moved out of this idiotic state and lived somewhere that actually lets you modify cars.
                                1990 325i
