driven and appreciated my 318 for more than 2 weeks before ripping out the m42. Not started an engine swap without a mentor.
What would you have differently, knowing what you know now??
http://l0st0n3.mybrute.com
http://l0st-0n3.mybrute.com
Work in progress: 1991 318i m50 swap
Feedback thread :up:
Originally posted by slammin.e28guyI prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
^Not having a mentor just makes victory even sweeter.
Originally posted by eandrade View PostWhat would I have done differently?- Removed all that rubber/foam insulation on the firewall.
- Remembered to disconnect that !~^%$~!# clutch line from the transmission before trying to pull the motor.
Originally posted by e30serg View PostBack from the dead! I'm getting back into my project and would like to hear some more ideas....
Having done a few I would not recommend an E21 booster or a NV motor unless you have immediate plans to boost. My NV car was on par with the M20 power, just quieter and got slightly better mileage.
I didn't get a lightweight fly and HP clutch kit this time, just what's stock to the S52. I think the motor is pretty powerful for this little car and it seems like an M52 would be a better balance for it.
Edit 1K posts suckas!Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.
Originally posted by eandrade View PostRemembered to disconnect that !~^%$~!# clutch line from the transmission before trying to pull the motor.2008 335i - n54b30
1991 318i - m52b28
1994 fzj80 - LAND CRUSHER
hello guys
i'm Gianluca , from Italy and I made the same work on my bmw z3. I have only one problem : i don't understand the electric cable of my s50b32 engine. do you understand the maps of circular connettor of that engine ? do you know the number of PIN what are? please can you help me ? ciao gianluca
Mr Swiss! Yup! Still got the moonroof! I was just looking at it the other day, seeing what needed to be done to get it fixed and installed. I ended up getting a Porsche booster.
Thanks everyone for your replies! Keep them coming! I'm already planning to remove the pan again and using some rtv on it. I would hate to have to remove that thing once it's on the car. I'm also replacing every gasket, seal and sensor. I rebuilt the s52 so it didn't seem right to slap on used parts back on it.
Originally posted by e30serg View PostMr Swiss! Yup! Still got the moonroof! I was just looking at it the other day, seeing what needed to be done to get it fixed and installed. I ended up getting a Porsche booster.
Glad to see old SN's again.Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.
Victor Reinz gaskets are shit, and that's a fact. Every which one I have bought never aligned properly with the bolt/screw holes and leaked.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.
Originally posted by Farbin Kaiber View PostUse a lift, and drop the old engine on the subframe, then put the new engine in on the subframe from the bottom.
Originally posted by etxxz View Post^^+11000213!!
they seal very well in my motor. Just make sure your surfaces are nice smooth and clean... and flat. If they are distorded is not the gasket's fault. I did goop up both sides of the oil pan gasket for safety.
Originally posted by eandrade View PostWhat would I have done differently?- Performed a detailed inspection on every single used part that I purchased from various other people.
- Purchased brand new knock sensors (the piece of mind is worth the couple of hundred bucks)
- Double checked that the @!*^&%~!# CPS wire was routed properly and not rubbing against the water pump pulley where it would end up shorting against the block and causing 5 AAA tows and countless parts replaced trying to chase down an intermittent misfire/no start that would ONLY appear when you were at least 10 miles away from home. Argh.
- Invested the money on learning how to weld properly (custom exhausts are expensive!)
- Cleaned my engine bay.
- Spent the extra time locating the parts that I REALLY wanted instead of going with a stop gap solution to hold me over (e.g. 3.46 diff instead of 3.73, Eisenmann exhaust instead of Magnaflow)
- Moved out of this idiotic state and lived somewhere that actually lets you modify cars.
