Lol, I believe you. PM or email me some pictures of your swap, if it's obd1, I wouldn't mind some good clear pictures of various connections if you got any. Good luck with your swap!
Jean, I've enjoyed reading your thread thus far and have made use of a few of your pics as I have been putting the motor back together. I have my obd1 m52 bolted in the car now and am in the process of hooking everything up.
I will try to get some pics up of everything soon.
Good luck with the swap.
-Nick
Nick,
That's pretty much why I try to keep a log, even if only 1 person finds it usefull .
Deff, post some pictures if you have time I could deff. use some for reference .
Good luck and I am sure it will fire up on first try :)
I'm currently in the process of hooking up all the cooling system lines and figuring out the wiring. I am trying to figure out the coolant temp sensor though. The shop I purchased the motor from converted the motor to obd1 already and they claim to have spliced the temp sensor to work with the e30 cluster.
I am uncertain how this is possible as everyone else seems to say this will not work for e30 swaps.
Got a 98 m52 today with ps pump, denso compressor, and headers for .. .... won't believe this, I still don't myself, under $200 out the door! Don't worry, once I get all the gaskets/hoses/brackets etc it will get up there in price as usual... This engine looks 10x cleaner than the m50 I had last week, no leaks and coolant is CLEAN! Pan and compressor coming off this week to start with. Ran a carfax on this one as well, just barely 100k on it.
Alternator, afm, starter should arrive this week. Got a lead on an M50 manifold/tb and fuel rail and injectors. Still need to find the e34 oil pan pick-up, as the oil pan I got is bare :(
Thanks Bruce!
So I found a great quote of yours....
Originally posted by Jean
Good start! I would love an m50 for $200 myself....
Are you going to upgrade rear brakes or just doing the fronts ?
Holy crap man, I didn't realize you responded! I'll pm you a link as to where you can find pics of the the motor.
Thanks man! I saved some of the pictures locally, I hope e36 bentley will be a good guide for me as well.
Haven't done anything with the engine this weekend as I was out autocrossing sat/sunday. I did get a vanos solenoid and e30/e34 harness plugs today to make an adapter, and hopefully 413ecu and e34 engine harness will arrive this week.
