Today was a good day
  • Jean
    • 18228
    #76
    Got it, that's what I was thinking but wasn't 100% sure. I'll stick with the plastic and spray the cover silver for the BAR peeps lol
    • Jean
      • 18228
      #77
      I just realized that it looks like i also need to source a vanos solenoid? Who can tell me if any 93-95 will work or if I have to get one specific to m52?
      Thanks Robert for the coils!
      obd1 fuel rail
      Got my manifold/tb/coils and had to test fit the manifold of course.
      obd1 tb
      I take it this sensor will stay in place but not plug into anything or is there a plug I can buy to replace it with?
      • Jean
        • 18228
        #78
        Two questions.
        Instead of drilling into the head can I use this instead with obd1 engine harness?
        http://www.turnermotorsport.com/html..._ID=TEN9989M50
        Another thing to order
        http://www.turnermotorsport.com/html..._ID=TEN9931007
        • e30serg
          • Dec 2006
          • 562
          #79
          The little harness deal won't work. I thought it would, but it was pointed out that it won't work with the e30 cluster.
          You don't need to order that pipe deal-unless you're set on using the obd1 coolant spider hose. You can use the metal pipe just fine, but you'll have to cut the obd1 wire harness bracket a little bit to fit.
          You can also get an obd1 timing case cover and it'll have that pipe already on.
          • Jean
            • 18228
            #80
            More information on exactly why that adapter won't work with e30 cluster?
            I sent turnet an email to confirm.
            I am set on using the obd1 coolant hoses since I have to order them anyway.
            • PiercedE30
              • Apr 2005
              • 4220
              #81
              NO!! Use the OBDII metal hose. It is SOO much less headache to use it than to pull it out and replace it with the little nipple that the OBDI timing cover has.
              My 2.9L Build!
              • Jean
                • 18228
                #82
                E34 pan, m52 oil filter housing, engine arms, tstat housing, tranny shield and mount all cleaned up.
                • Jean
                  • 18228
                  #83
                  What's exactly is the difference between M50 and M52 vanos solenoids? If I am going to run OBD1 vanos harness do I need to make sure I also use an m50 solenoid, will the m52 solenoid not work?
                  thanks
                  • e30s52
                    • Oct 2007
                    • 5235
                    #84
                    with the obd1 the connector for it is longer by about 4-6in. i used the obd1 coolent hose and its not a big deal at all
                    www.gutenparts.com
                    • Jean
                      • 18228
                      #85
                      Turner says it works, does it or just a sales pitch? lol
                      From: Doug Mahar [mailto:dugmar@turnermotorsport.com]
                      Sent: Monday, August 11, 2008 2:03 PM
                      To: Jean Minasov
                      Subject: RE: http://www.turnermotorsport.com/html..._ID=TEN9989M50
                      Yes, we have used this in E30 conversions many times.
                      -Doug
                      Douglas Mahar
                      Turner Motorsport
                      www.turnerMINIsport.com
                      www.tmsracing.com
                      www.allshocks.com
                      Phone: 800 280-6966 x 1
                      Fax: 978 388-4202
                      - 2003 & 2004 Speed Touring Car Champions -
                      - 2006 Grand Am Cup GS & ST Champions -
                      Sent: Friday, August 08, 2008 9:24 PM
                      To: Doug Mahar
                      Subject: http://www.turnermotorsport.com/html..._ID=TEN9989M50
                      Hello,
                      I have a 98 m52 engine that I am converting to OBD1 and then installing into an E30. Will this adapter work with an OBD1 engine harness
                      In an e30 chassis with e30 cluster?
                      Thank you.
                      • e30s52
                        • Oct 2007
                        • 5235
                        #86
                        i have it. it doesnt work! if you want mine i will sell it to you for like 20 bucks shipped. it didnt work with my swap so i dont know how it would work with yours.
                        www.gutenparts.com
                        • Jean
                          • 18228
                          #87
                          Injectors are here, thanks Daniel!
                          Next to purchase - Vanos Solenoid, Sensors, Harness and ECU.
                          • sharksforthecup
                            • Aug 2007
                            • 246
                            #88
                            dont buy the turner wiring adaptor.
                            • surebimmer
                              • Jan 2004
                              • 978
                              #89
                              +1 I bought it and it didn't work.
                              Have the machine shop drill and tap the head when you have it off the motor. There is a boss for it.
                              • Jean
                                • 18228
                                #90
                                Removed the e36 pan and test fitted e34 pan and s50 valve cover. Need to order correct oil pick-up, dipstick and tube, and possibly new oil pump.
                                I noticed obd1 valve cover can't use obd2 style gaskets around the ignition/spark plug holes. So I take it I need to order obd1 m50 gasket set?
                                these can't be used with obd1 valve cover
                                maf
                                alternator
                                starter with threaded holes
                                s50 valve cover (thanks Hugh Jass). Thinking about getting it media blasted and powder coated as I don't want to run the plastic covers over it.
                                Need to figure out all the little things to order as well
                                e36 pan removed
                                100k on it, should probably get a new oil pump?
                                test fitted e34 pan
                                all holes line up, but need to remove the e36 oil pickup tube bracket so two main bearing bolts will have to be removed
                                this one
                                starting to have a collection of parts lol
