S5x,M5X To Getrag 260 shift arms
  • mattdk318i
    • Jun 2006
    • 3953
    As the title states, Ive had a modified shifter carrier and selector rod for several thousand miles in my cabrio.
    I modified them as precisely as i could and apparently i did something right. The shifter works perfect and even with a SSK. I wanted to wait a while before duplicating this for a sort of R&D period. Yes, the shifter is centered. That was the point of this mod. I can sell a "Kit" with the modified trans mount too.
    So now im ready to offer my services to you guys, What should i charge and will there be any demand for these? I will be welding aluminum and steel.
    I will need cores, Maybe Joe funk could hook us up.
  • z31maniac
    • 17566
    Definitely interested. I'm looking to do a 24v swap in the spring and want to use the Getrag 260.
    www.gutenparts.com
    • mattdk318i
      • Jun 2006
      • 3953
      alright man, just let me know
      • Nick325is
        • 1409
        Definitly interested. I don't have alot of time to fab stuff up with my work schedule so something like this would be perfect. I can send you my core if you would like.
        let me know.
        Thanks,
        Nick
        • rThor432
          • Feb 2007
          • 3907
          Yeah I'm interested as well. I can send a core also. Let me know what it's worth to you..
          Also, nice sig. Bumperless black E30 reminds me of mine. haha.
          • mattdk318i
            • Jun 2006
            • 3953
            let me know.
            Thanks,
            Nick
            Alright sounds good.
            • mattdk318i
              • Jun 2006
              • 3953
              Thanks, i think the satin is going to look good. Especially slammed on DSIIs.
              Do you guys think 100ish plus around 60 for the Trans brace is fair?
              So say $150 including shipping for the whole package? Provided you send cores?
              Or 75 for just the shifter Modification. Ill put up a For sale thread when i get some feedback i suppose.
              • rThor432
                • Feb 2007
                • 3907
                Sounds good to me. Saves me time that I dont have.
                • hoveringuy
                  • Dec 2005
                  • 2738
                  I did mine during the conversion but it took some time that I was short on, especially since I had to make some adjustments for trial and error; and take everything apart again when it rubbed the driveshaft slightly in 5th gear. Z3 shifters make this a little more critical.
                  I would recommend it because it would save a bunch of time and it's just one less thing to hassle with.
                  Don't forget your OBC conversion, too!
                  • mattdk318i
                    • Jun 2006
                    • 3953
                    im still trying to decide whether its worth crawling under my cabrio removing the shifter parts and then making a jig.
                    Let me know guys.
                    • RobertK
                      Kicked cancer's ASS.
                      • Jun 2005
                      • 5864
                      I'm confused, I'm using the Getrag 260 with my M50 swap and all I did was bend/twist the selector rod a few degrees then bend the new shifter to match the stock on and my shifter is centered just fine.
                      • mattdk318i
                        • Jun 2006
                        • 3953
                        i would suppose thats obviously possible. It gave me piece of mind to have mine welded, to avoid any problems(if any)
                        • RobertK
                          • Jun 2005
                          • 5864
                          I gotcha, I couldn't tell before since I am posting through my BlackBerry the pics are too small.
                          I also ended up using the sheet metal shift carrier instead of the aluminum one.
                          • mattdk318i
                            • Jun 2006
                            • 3953
                            thats probably the difference. Because with the aluminum, i didnt see any way to do it, without making it look awful and functioning about the same.
                            Because Cast aluminum tends to break if you twist it.
                            • JRKOUPE
                              • Dec 2004
                              • 3159
                              metal vs alu
                              I get confused.........which cars used metal vs alum?...
                              Your mod is appealing to me and Id be on board..... as Im headed s 50 w/ my g260...
                              I use Dennis' modded trans bracket.....
