should be about 3k, with a 3.73. 6,500RPMs in 1st and second are at about 30 and 50 mph, respectively.
					[HOW TO] e46m3 6-speed your e30
 nice write up. just asking how much did this cost?Comment
 "A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
 Friedrich NietzscheComment
 Will do. I have to get under it to install a 24V skidplate anyway - I'll take a look at the casing when I do it. M4tt was convinced that it's a 3.46:1 *shrug*.
 E30 24V 6MT SOLD :( - look for it in sunny Miami :)Comment
 when we were at lunch I wrote down on your list AND told you it was a 3.25:1. Just check it, if you like it then there is no real reason to change it right?"A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
 Automatic E36 M3 drive shaft fit confirmed! One small hiccup, you need to change out the CSB to one that will fit the E30. Other than this one problem the only thing (custom) you need to make is the transmission brace. Now I need to figure out if I am going to run a 3.46:1 or 3.73:1 LSD"A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
 changes made to teh write up to reflect this new informatione30sport.net
 '06 M3 Competition - 6-speed
 '97 Range Rover VitesseComment
 For those that did this swap, can someone please post some pictures of the modified cross member, and what they did? With the new info about not having to get a custom driveshaft made this is now a "must do" for me. I'm already running a 3.73 rear gear so I think this will be perfect for my car. Thanks, Christian.08' BMW M5
 07' BMW Z4M Coupe - SOLD
 95' BMW M3
 87' BMW 535is
 Bring Bangle Back...Comment
 Shameless F/S post
 This is a PIC i found off of the Azevedo Motorsports web page. It is just basically an extension from the manual brace rail to the brace that sits out in mid air. I am going to be making a few of my own brace (adapters) for myself and a friend. All you will need to do is bolt the (adapter) on the car and then bolt the brace to it. My adapter will bridge the manual to auto rail."A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
