The Infamous No Fuel - No Spark
  • Jean
    • 18228
    #61
    Originally posted by RobertK
    FYI.. Brand new M50 CPS measure 901 ohms
    What's the brand or part number on it?
    I am going to post my finding in about an hour.
    • rs4pro3
      • 5808
      #62
      Well that is closer to the manuals, the range on the e36 bently is for it to be within 1152 to 1408 ohms
      85 325e 2.7 ITB'd stroker
      • JGood
        • Jan 2004
        • 7959
        #63
        Originally posted by bimmerforums.com
        I had a hunch that it was the crankshaft position sensor. I checked the resistance on it per Bentley and found it to be 549 ohms. Since this is less than the spec found in the Bentley (1280 ohms), I said voila.... problem solved. So I went to the dealer and bought a new CPS. To my surprise, the new one read 545 ohms. What the heck... I installed the new one anyway. Unfortunately this did not solve the problem. Subsequent to this, I read the Mar 02 Roundel article on CPS and the author said most 1 sensor (CPS) DME systems should have a resistance value of 540 ohms. This was my experience so I'm not sure why the Bentley is wrong on this.
        http://forums.bimmerforums.com/forum...p/t-41233.html
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • JGood
          • Jan 2004
          • 7959
          #64
          Originally posted by roachfly
          Yes, about 500 ohms is correct despite what Bentley says. I checked resistance on a new crank rpm sensor at the dealer when mine was suspect and it measured about 500 ohms as well.
          • Rocla
            • 922
            #65
            This same problem often occurs when you install later m20 motronic to pre -88 car. Later cars AFAIK don't have this problem.
            I have no right solution for it, I've just allways cut the wire from ecu to relay and ground the relay. That naturally makes fuel pump run allways when key is turned.
            EDIT: some harnesaes have smaller green wire on other pin of engine harness socket, older car lack a splice for that wire on car side socket, make sure that the engine harness smaller green wire has sam +12 on ignition shwitched as the bigger green wire has.
            Current:
            BMW 320i 2d 2.0 m20 -88
            BMW 325i Cabriolet 2.5 m50 -88
            BMW 316i touring 1.6 m40 -90
            BMW 320i 4d 2,2 m54 -01
            • Jean
              • 18228
              #66
              Just checked mine and it's right at 540ohms (confirmed with TWO digital multi meters)
              • RobertK
                Kicked cancer's ASS.
                • Jun 2005
                • 5864
                #67
                Yes, both multi meters gave the same read on the bad sensor and the good one. Regardless the new one is 400 ohms higher than the old one.
                540 is a good read out for a M20 CPS from what I've read in the various manuals.
                • rs4pro3
                  • 5808
                  #68
                  Originally posted by Jason89i
                  i just looked over your x20/c101 adapter. pull e36 x20 p7. (e30/e36 immobilization does not work well together.)
                  cheers, jason
                  Well that ended up being the problem, Robert disconnected that wire and the engine fired right up. So for anyone else doing an m50 swap into a pre 88 e30, do not send 12-volt to pin 7 of the e36 x20 plug.
                  • FredK
                    • 14761
                    #69
                    Sweet! Mucho props to Swap Doctor, Jason89i! :mrgreen:
                    • Jean
                      • 18228
                      #70
                      What were the "bad" and "good" values?
                      I measured 540 on a m50 cps, not m20 for the record. So is it confirmed, both bentleys are wrong?
                      • RobertK
                        • Jun 2005
                        • 5864
                        #71
                        I believe so.. turns out the CPS that my friend picked up for me was for a M52 anyway.
                        So yeah.. IT LIVES!! All that for one little wire.
                        Just in time for chemo tomorrow. Hopefully, if I don't get too sick from this round I can get it to the exhaust shop on Friday.
                        Thanks to everyone who chipped in.. especially Jason89i, you're a life saver! Atleast now we have the answer to this issue documented.
                        EDIT: JGood this might be the same problem you're having since your car is pre-88 as well.
                        • JGood
                          • Jan 2004
                          • 7959
                          #72
                          My car lives as well :)
                          More info to come when I verify a few more things...
                          I believe my problem had to do with corrosion of connectors. DOH!
                          • RobertK
                            • Jun 2005
                            • 5864
                            #73
                            Awesome to hear!
                            • Stevie30
                              • Apr 2007
                              • 1534
                              #74
                              Great! No more Ole Smoky.
                              1991 325ic and 1991 318is
                              • mattdk318i
                                • Jun 2006
                                • 3953
                                #75
                                amen, though last time wasnt so bad. Because i wasnt in the drop top
