plastic is good.... anyway, good work man
Another S52 swap... but this time with a newb!
Just to update this thread.
Year after the swap everything mechanically was smooth.
The dyno was done about a month ago.
But today, I recently bought a Walbro GSS307 for 40 dollars brand new. My OE pump went bad so it was time for a change.
I started off with this
And ended with this
Hopefully this lasts long enough.
In general in the past year I've done the following since the completed swap:
- New Water Pump (Metal impellar)
- New s52 valve cover gasket for my s52 plastic valve cover
- New Walbro 255lph Fuel Pump
- New a/c drier for my functional a/c
The money and time for this swap was well worth it. Next is boost. =)
SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]Comment
You need more rubber before you can think about more power. :pCheck out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Wow, I can't believe I just read 36 pages of this thread. Nice car man!!! Doing the same swap right now. Just waiting on the sensors and mounts before I actually get this thing in the car.
Was looking forward to the bolt to drive write up, mainly on the electrical side, but I imagine a year after the fact things get a little blurry. BTW what manuals did you use for your harness? Any more helpful than the other? Most of the diagrams I keep coming up with are for the 318ti.
Anyhow, as someone thats going through this right now for the first time I appreciate the write up. Always interesting to see how everyone pieces their cars together.
Sam
Originally posted by Roysneon$5 shipped?Originally posted by MarkDYou are a strange dude, I'n not answering any more posts from you.Comment
Do you happen to have your emmissons test papers and also are you using the pink top injectors with the stock MAF?
thanksComment
Sam
Bare in mind, e36 vanos wire colors should all be the same, unlike the e30 engine side/body side vary within different years.
Also, these diagrams are what people already posted within this forum.
Suspension:
-Ireland Engineering Stage 3 springs
-Bilstein Sport Shocks
-Ground Control RSM
-Ireland Engineering Race Subframe Bushings
-Ireland Engineering Polyurethane Trail Arm Bushings
-Treehouse Front Control Arm Bushings
Still need to buy sways and Coil-overs.
obd1 s52 with 24lb TMS Injectors, 3.5" HFM (540i/740i obd1), Silver Label 413 with Chuck&Stickley Chip for mentioned mods, Obd2 headers, 1998 obd2 m3 midpipes, custom catback. Passed pretty easily.
Let me scan the papers with some editing of course.
I have my emissions test papers. I could scan it. The setup I used for the smog is the exact setup I have.
Let me scan the papers with some editing of course.Comment
Did they make you do a test at idle too?Comment
