E34 wiring harnes/ecu question
  • flyboyx
    • 8371
    i am looking at a couple of e34's for parts to do my 24v swap. both cars are 92's. one manual, the other is auto. i am told i need to run the red label 413 ecu. which i believe was not available until 93 or 94. can i use this harness with that ecu? i would prefer to buy the manual trans car over the auto, because i think the parts would be easier to sell. unfortunately the manual trans car is more expensive. any advice would be appreciated.
    Gigitty Gigitty!!!!
  • Uber E30
    • 1409
    Manual harness is a little easier to do the swap with. Also i could be wrong but im pretty sure any of the m50's w/ vanos came with a 413 red or silver label. Either you can use since im sure you will be chipping it anyways. The first run of e34's with vanos was september 92.
    -Alex
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      IIRC, e36 harness is a bit of a better choice due to length for the ecu installation.
      • 2002maniac
        • 4260
        Those 92's are non vanos. You'll have to use the stock ecu.
        • Uber E30
          • 1409
          Actually 92 was the first year of m50 vanos, as stated in my first post.
          -Alex
          • 2002maniac
            • 4260
            September 1992 production would be a 93 model.
            • Mako18
              • Jul 2006
              • 688
              RED LABEL 413!!!!! silver = ews which will need a chip to bypass this function.
              • formula driver
                • 2263
                But if your gonna be chipping it anyway than this shouldnt matter correct? Which one is more desirable?
                • e30s52
                  • Oct 2007
                  • 5235
                  /\ It will cost about 50 bucks more to have your chipped formatted too a silver lable ecu.
                  www.gutenparts.com
                  • hoveringuy
                    • Dec 2005
                    • 2735
                    Not true! I had a silver label with no EWS. It was out of a '94. After '95 they had EWS.
                    • Uber E30
                      • 1409
                      Uh, no, it says the date your car was manufactured on the vin tag. Have you ever looked at real OEM? Thats why stuff like this have a date of 9/92 and up.
                      -Alex
                      • matt
                        • 3732
                        Uhh yeah... because any car made after 9/92 would be a 93.
                        I really wish some of you guys would get an understanding about how EWS actually works instead of just reposting the same BS you read in the big thread or wherever.
                        • formula driver
                          • 2263
                          My thoughts exactly, you fella's definatly confused me a bit.
                          • 2002maniac
                            • 4260
                            you're retarded. And wrong. All 1992's were non-vanos. Yes, production of 1993 models began on september 92, but that is not relevant.
                            • Mako18
                              • Jul 2006
                              • 688
                              whats confusing? two choices here? 1. red label = no chip to delete ews
                              2. silver label= chip to delete ews. (unless its a pre 95 silver label) Now if your doing something special to the engine such as cams, inj, hfm...etc etc then yes when you get the chip for the above & at the same time they can do whats needed to delete ews function.
                              Now if this is wrong someone needs to correct this because its all over the 24v swap sticky. I have a red label along with many others with no issues or modifications needed for a stock m50b25.
