individual grounded coils (Homebrew ghetto rig) Remove?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    So, i'm helping a friend with a 24v, his coilpacks are individually grounded, in a strange way.
    What do ya say?
  • bender
    • May 2004
    • 171
    i'd say i'm not even sure if thats needed.
    do you ground a normal coil like that? no
    600hp beast
    • kenika65
      • Aug 2007
      • 1336
      well it will definitely prevent loosing ground to your coils, but as long as the engine is grounded then you dont need that, just need the coils bolted down.
      Someone put some time in to that.
      1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
      1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
      • kronus
        • Apr 2008
        • 13032
        Yeah, that's unnecessary unless the main engine ground is crappy or noisy. Remove it and check the potential drop between the coil pack ground points and the car chassis. If it's not zero, something is wrong and you need to check the engine ground.
        Also check current draw on the battery when the car is off. If it's bigger than like 100 mA, there's a ground issue.
        cars beep boop
          • 34847
          overkill, but extra grounds aren't going to hurt anything.
          • hoveringuy
            • Dec 2005
            • 2754
            I thought it was strange when I wired the M54 that the coils were grounded directly through the harness, and then were grounded through a resistor to the engine.
            I don't know the reason for that resistor, but it makes me wonder about grounding the coils directly!
              • 34847
              I bet it was for noise filtering, like resistors in plug wires.
              • hoveringuy
                • Dec 2005
                • 2754
                Yeah, I'd say that's a good guess. I can definately see it on the secondary side, but the primary?
                • 318isbmw
                  • Nov 2005
                  • 2843
                  Actually the 24valves have 2 grounds on the coils. I cant remember which numbers, 1 and 6 I believe? If you've got the regular grounds on the coils, I wouldn't worry about it. I guess better safe than sorry though...
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    Yeah, we left the OE ground straps on coils 1 and 6. they are all tied via a galvanized plate.
                    • 1990m3
                      • 1180
                      I've found this to only be true on the obdII motors. All obdI motors I've seen only have one ground on the coil closest to the firewall...cylinder 1?
