California BAR smog referee woes
  • hugh jass
    • 2220
    Originally posted by Bmjpv
    Sorry to hear about all that. This is most likely your problem , California has Smog Inhanced Areas, Santa Clara Valley is one of them, LA basin,Santa Diego is another. I beleave Sacto is Not . Yes you have to have California EPA approved cats and so on. I Lived in Santa Cruz (long time) and owned a Import shop where that county is Not Enhanced and has less pressure from the state to compling standards . Yes, it is way too subjective for a state emplyee to make that call if he/they are in a bad/picky mood that day.Now you in their system, Comply or move your zip code. Good Luck ,Joe
    sacramento is an enhanced area
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    • george graves
      • 19997
      There are non-smog areas in CA. Well, you only have to smog when you sell. I'm in one of them.
      Originally posted by Matt-B
      • BimmerToad
        • Sep 2004
        • 1537
        Sorry to hear that. I successfully had my M52 w/ S52 cams ref'd as a '95 M3 3.0L with no trouble, (once I tackled down an air leak at the 02 sensor port in the exhaust).
        I'm amazed that you have to have the original exhaust configuration of a '95 M3. My car was able to pass as a '95 M3 with a single 2.5" exhaust system. Talk about variations in smog refs!
        For future swaps, you might be better off passing the M/S5X as a '93 M50, since smog emission levels of a '93 engine aren't as stringent as an engine from a later date.
        San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
        • cactusjacks1
          • Sep 2004
          • 1216
          In CA - smog can be a very subjective experience. As the "it's swapped & passed" threads tell you, it really depends on the mood of the referee that day. Their is an explanation for the hoops they made you jump through - the mood the last 2 mos. at referee stations has been real low - they all lost their jobs due to the budget problems in CA. That's right, all CA smog referee stations are locked up - it's happened over the last two weeks. It looks like their work responsibilities will be passed down to the "test only" stations. That should make your problem easily solvable.
          When someone in CA says "is it a clean engine?" they don't mean spotless as you inferred, they mean does it blow clean? or how are the emissions. What were your numbers? Post them up!!
          [I
          • rThor432
            • Feb 2007
            • 3907
            Man that's a bummer. I went to the inspection station with one of my cars and the guy that inspected my car had an S50 E30 with straight pipes. NC rocks for inspections I guess..
            • surebimmer
              • Jan 2004
              • 978
              I went to get my car ref'd as well I'll post my number's and details when I get to a scaner.
              • e30serg
                • Dec 2006
                • 562
                Hey Kyle-did you pass? You have your s52 looking like an m50 right?
                • trent
                  Originally posted by jahnaboi
                  Trent, which station did you take yours too?
                  Uhh, if you read I said both. Chula Vista and Miramar.
                  • grib
                    • Oct 2006
                    • 151
                    Thanks for all of the replies. Just to respond to a couple of the questions/comments…
                    Can’t register outside CA. I have family in Idaho and had the car registered there for many years. However the CHP stopped me in 2003 and made an issue out of it. There was actually a CHP officer working it directly, that followed me to two different residences and almost resulted in the car being impounded. I think that if I were ever stopped in CA with out-of-state plates again it would be a problem.
                    The numbers were not clean from the car, which is the only part that I do feel bad about. Mostly it’s the NOx levels, which are currently past gross polluter levels. Even if I had subverted the system in some other way, I would still endeavor to fix this. After doing quite a bit of reading, I think it basically comes down to the aftermarket cats being crap. I’m running a Magnaflow which I purchased new from the exhaust shop, and was supposed to be oversized for the engine and CARB compliant. From what I have read; even the best aftermarket cats don’t seem to do the job…. so why do they sell them? The quote on new OEM cats was $2,300 which is obviously out of the question. I spoke with the shop that did my exhaust originally, and they have recommended going back to stock cats. They are a reputable shop, so it’s a little disappointing that they didn’t mention the implications of using an aftermarket cat when we first started. I am trying to source a low-miles OBD-1 mid section and plan to go back to using as much of that setup and design as is practical. This should bring the numbers back into normal levels, which is a repair I have not problem making.
                    Really interesting to hear the different experiences in different counties. I wasn’t aware of the budget cutbacks cactusjacks mentioned – do you know when this goes into effect? My appointment was on Dec 12th at Evergreen Valley College in San Jose. If this takes effect in January, for example, it might be worth it to wait. When I make my next appointment I might see if it’s possible to visit another location, Evergreen College wasn’t really close to my place anyway. Prior to that I plan to “pre-test” the car at a smog shop so that I have something objective to compare to.
                    Like I said above, the numbers aren’t clean right now. But the focus of the test wasn’t getting these numbers down – it was pointing out all the other little things. For example, my PCV plumbing was failed – but looking at diagrams and my parts receipts I have the correct setup for a 95 M3. And is anyone here actually running an E36 charcoal canister? He told me that it needed to be setup and mounted EXACTLY like the E36, which is placed in the fender. There is no way I am going to stick that thing under the crowded E30 fender well. If anyone is running it I’d be curious to see a few pictures. Either way, I doubt this will do much if anything to lower the actual test numbers
                    The bottom line is that I really do want the car to be clean and legit. I spent a lot of money trying to build a clean, well-tuned engine (including the exhaust). One of the reasons I swapped the M20 out in the first place was that it was having some trouble passing smog.
                    1987 325i Cabrio - SOLD
                    2014 Chevy Volt
                    2007 FJ Cruiser
                    • Jon325i
                      • 6934
                      Have you tried contacting Alpine E30 (a.k.a. Alex - he posts on BayE30 as well). He was recently trying to sell his '89 325i sedan with M50 swap that was fully legit....right down to the referee's blessing including the tags issued. Perhaps he can lend some insight. He works at Valley Motorwerks in Rancho Cordova, CA.
                      Jon
                      Rides...
                      1991 325i - sold :(
                      2004 2WD Frontier King Cab
                      RIP #17 Jules Bianchi
                      • BimmerToad
                        • Sep 2004
                        • 1537
                        The magnaflow cat should be no problem. I used a universal 2.5" magnaflow cat and passed the CA sniffer with no problem.
                        If your NOx are high, maybe you're running too lean. What are your CO and HC levels? Are you failing at the 15 or 25mph test?
                        • White Nightmare
                          • Jul 2006
                          • 376
                          I have done it before and it was super easy. You just have to do your homework before you go down there. The gas cap thing is super old, I think your mistaking that for the EVAP test that started December of last year. If you go to the BAR website they go into detail of what needs to be done. I'll agree that its total bullshit that any of this has to be done in the first place but at the same time it sounds like you didn't prepare yourself or do your homework prior to going there.
                          -Chris
                          Big Brain- "The big brain am winning again! I am the greetest! Now I am leaving earth for no raison!"
                          - California Certified Smog Technician -
                          • e30polak
                            • 6136
                            I heard that there is no more ref, and that you just go to a smog station now?
                            INSTAGRAM: @UNDR8D_EMPIRE
                            • Jesse30
                              • Jan 2007
                              • 3936
                              ref's been back for a couple months now man...
                              • bmw320e21
                                • Jan 2005
                                • 67
                                Any updates on your inspection?
                                Adam
