What do they charge for the visual? I'm to lazy to look it up
California BAR smog referee woes
visual only now wtf? I had to smog my 84 m10 3 months ago, pipe test only. Luckly I have friends In high places, but still had to test on the dyno. This was in June. Has anything changed since
They did visual on your car. but there's nothing to fail on a stock m10. Unlike a 24valve swap or a m30 because of the visual difference . And stock cars dont get visual from state referee. There's a difference we have to get our swaps approved buy CARB thats what the visuals for.84 318I Delphin RIP
87 325IS delphin 24v Sold
89 325 AlpineweissComment
The ref used to do a full smog check which consisted of a visual, functional and a emissions check.
From what people are saying they will only perform the visual aspect of the smog at the ref office. Once that is ok and checked off you will need to have it smogged at a normal smog station. In which case they will smog the vehicle according to whatever engine is in it.
This is a stupid for CA because they will loose money unless they charge the same as they did but do less work. If this is the case it will also help out the smog shops.
-ChrisBig Brain- "The big brain am winning again! I am the greetest! Now I am leaving earth for no raison!"
- California Certified Smog Technician -
All shops are suposed to do visual. But test onlys pick you car apart.84 318I Delphin RIP
When I went to the BAR referee I was only charged the $8.25 or whatever for the certificate. I was not charged for a "smog test" (usually $40-75 at a shop) even though he performed one.
It doesn't seem like this was a revenue generating program for them, just another piece of our giant, bloated bureaucracy. Approx 3-4 hours were spent directly on my car with average 2 techs at a time. Very costly from a direct labor standpoint...
1987 325i Cabrio - SOLD
2014 Chevy Volt
2007 FJ CruiserComment
Congrats dude, good luck with smog! Weird how they give you the sticker FIRST and then send you to smog shop LOLMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
They would have to otherwise the smog shop wouldn't know if the swap was legit or not. The sticker indicates to the smog techs that the engine swap has been checked by the state ref and is good to go.
SPCN (special construction) vehicles need to go through the same process but through the CHP to retain a SPCN sticker before they can be registered.
Yeah it makes sense...when I wanted to pre-smog my car the smog check told me he needs to see the sticker first as well. I guess when they give you a sticker they MAKE you go to a TEST ONLY station right?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Livermore at las positas collage. I had been there before and they just gave me a once over and said well they will check it when you get smogged.Last edited by surebimmer; 09-10-2009, 07:44 PM.
Congrats Surebimmer! Local referee station didn't charge me anything for my inspection either, process went smooth and I got the sticker as well :)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
