Starting my M54B30 swap...
  • Elysian
    • 674
    #106
    Also, I've got a pinout for the stock DME now, finally found it in my Bentley, I think I'm going to try to fashion a harness similar to hoveringuy's Motronic harness.
    • Elysian
      • 674
      #107
      Originally posted by nando
      they make thermal heatsink tape just for this, try a computer/modding site.
      I was also thinking a thermal adhesive, I've used Arctic Silver adhesive in the past, but it'd have to be the type they make that's non-conductive, I think it's called Ceramique.
      edit: no the non-conductive adhesive is actually the Arctic Alumina.
        • 34839
        #108
        yeah you probably don't want to use a conductive paste (I've got a tube of arctic silver from 10 years ago!). I'd think the thermal tape would work best, it's more of a epoxy than a tape though.
        • Elysian
          • 674
          #109
          This is what I'm talking about, it's literally an epoxy. I also like to have this stuff handy because I also water-cool my computer, it helps when I need to attach something Guess I'm taking a trip to Frys for a heat gun and some Arctic Alumina.
          • hoveringuy
            • Dec 2005
            • 2715
            #110
            You could leave them on the board and cut the board out around them. That way they're mounted and have some heat sinkage.
            You could then scrape off some of the protective screen and solder output directly to the pad.
            • Elysian
              • 674
              #111
              Oh good call, that'd make things a lot easier.
              Would a heat gun be the best way to get the main connector off of the board?
              • hoveringuy
                • Dec 2005
                • 2715
                #112
                Yes, heat gun. hold the board in a vice. Make sure the connector isn't mechanically attached to the board in any way (screws, snaps, etc.). Practice on some of the chips to get a feel for the solder. Start on the end of the plug away from the coil drivers and work your way down. As you heat from the back gently pry and it will slide out like buttah.
                • Elysian
                  • 674
                  #113
                  Excellent, just picked up a Hakko 1300w heat gun.
                  • Elysian
                    • 674
                    #114
                    There we go. Now to cut a pair of holes for the MS3X and main harness.
                    • Elysian
                      • 674
                      #115
                      Here we go. I decided to have the drivers just go in order, 1-6. I sorted out the firing order in the MS3X harness. I've checked continuity and made sure there are no unintentional connections anywhere. I used the middle connector instead of the back connector for ease of soldering.
                      • hoveringuy
                        • Dec 2005
                        • 2715
                        #116
                        It runs! Got it to start and idle on MS3. Had a small hiccup with the ICV but now it idles fairly well. Need to find a decent Ignition chart that doesn't go up to 300KPa.
                        See the progress at http://m54megasquirt3.blogspot.com/
                        • Elysian
                          • 674
                          #117
                          Nice! Wish I already had the motor in the car
                          • Elysian
                            • 674
                            #118
                            Took resistence measurements on my coolant temp sensor today. Need to pull the intake air temp sensor and do the same.
                            • Elysian
                              • 674
                              #119
                              Worked more on my wiring today, found some errors I made and corrected them. Whoops.
                              • Elysian
                                • 674
                                #120
                                Well guys, logic has set in and I've changed my mind yet again. This thread is now relevant to this forum again I'm putting the M54 into my E30 after all, it will make it so I have no downtime with my DD. I'll still be turboing it down the line. I need to order a new pair of engine mounts(probably urethane, love the ones in my E24) and I need to change the brake booster. Once that is done everything will be in line to drop the motor in.
