Metric Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
  • Andrew325is
    • Jan 2008
    • 1210
    #241
    I've teamed up with Markert Motor Works to offer a performance swap tune tailored to your mods. Now you can take care of the wiring, EWS delete flash, and tune all in one shot! :)
    It will be $400 with the purchase of a harness or EWS delete flash.
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
    • oldschool bimmer
      • Jun 2017
      • 1
      #242
      M52tu › E21
      What is the best way to run a M52tu in a E21? just as original as possible
      • sassen
        • Nov 2013
        • 28
        #243
        I sent you email about s54 wiring harness and ECU flash. Can you check your email please..
        Thanks
        • Andrew325is
          • Jan 2008
          • 1210
          #244
          I sent one to the UK, Ireland, France, South Africa, Australia, Canada, and Brazil. These are going all over the world.
          • mpwrcpe
            • 83
            #245
            Shot you a PM Andrew.
            -Dave
            _________________
            -15 Pure White/Anthracite VW Touareg TDI Lux
            -95 Avus M3 S54B32 Race car
            -72 Chamonix 2002 (New project)
            -90 Calypso 325ic (70K Original miles)
            -00 M Coupe - Sadly sold
            -97 328is - Sold
            -90 Sterling 325is - Sold
            -73 Taiga 2002 - Sold
            • Andrew325is
              • Jan 2008
              • 1210
              #246
              I'm finally able to make an MS41 bench flashing harness. The pins for the ECU connector are obsolete, but I found a supplier who still had some.
              • mitch500
                • Jan 2006
                • 1092
                #247
                Just picked up a s54, I'll be contacting you shortly for a harness :)
                1988 e30 alpine white vert 5speed
                1987 e30 325 eta
                1983 e28 533
                2001 x5 4.4l
                1997 e36 M3 Alpine white 5speed
                1991 Jeep XJ I6 4.0
                • 2jzeverything
                  • Nov 2017
                  • 2
                  #248
                  Do you have a harness to run a m52 engine in a m54? I have got myself i perfect running 1997 BMW 328i that i got for a steal, and using it to replace the 2001 325XI engine. i know everything bolts up and fits the same/ish but i read a while back there were only a couple things that would need to be added. Thank you for you time in advance!
                  • Andrew325is
                    • Jan 2008
                    • 1210
                    #249
                    I don't make a harness for that, but I make one going the other way around. That would be a rather difficult conversion. The E46 has different electronic requirements, including ABS (and the AWD system), CAN bus, K-line, EWS, etc. Alpina put an M52 (3.4l) in an E46, but they used an MS43 ECU and drive-by-wire throttle.
                    • 2jzeverything
                      • Nov 2017
                      • 2
                      #250
                      ahhh yes i have everything needed, two COMPLETE cars, just the e36 is tottaled and the e46 has a blown engine, do you think i could run the same computer and leave the wiring in the e46 just by adding whatevers missing onto the e36?
                      • Andrew325is
                        • Jan 2008
                        • 1210
                        #251
                        You can't use the E46 computer with the E36 engine. The only practical exception would be the 3.4l Alpina engine and it's associated bits. I recommend selling the E36 and purchase the correct engine for the E46. You could install a 3.0l M54 without much hassle. It would be a nice upgrade.
                        • Otto_E28
                          • Nov 2017
                          • 1
                          #252
                          I messaged you about a harness! Thanks!
                          • Andrew325is
                            • Jan 2008
                            • 1210
                            #253
                            I sent you a message back. :)
                            • Andrew325is
                              • Jan 2008
                              • 1210
                              #254
                              Someone's first start with one of my S54 harnesses. :)
                              • mitch500
                                • Jan 2006
                                • 1092
                                #255
                                tis mine ;) thanks again.
                                1987 e30 325 eta
                                1983 e28 533
                                2001 x5 4.4l
                                1991 Jeep XJ I6 4.0
