Metric Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
  • cek
    • Jan 2014
    • 85
    #256
    Originally posted by Andrew325is
    Someone's first start with one of my S54 harnesses. :)
    I forgot to post mine (E28):
    Thanks Andrew!
    Vlad: '87 535is │ Maytag: '87 528e │ '88 911 │ Project Minerva - S54 E28
    • Andrew325is
      • Jan 2008
      • 1212
      #257
      Someone just sent me a link to an online store (Garagistic) selling harnesses that resemble mine asking if I make those too. No, those are not mine. My harnesses are only available from me directly and occasionally on eBay under username "TekE30" only. Garagistic, or whoever is making them, has done a good job copying the appearance of my harnesses, but the wire sizes are completely wrong. There is also no way to tell how they are wired. Therefore those harnesses may not function as expected and may be dangerous to use.
      Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
      • Th3 shifty
        • Sep 2016
        • 2
        #258
        hey quick question... is the terminal 30h powered only when the ignition is on? I checked with my multimeter with ignition on AND off and i have ZERO volts at it.
        issue that happened, while driving, negative cable came off, killed the car, it cranks but wont turn over, INPA cant find the DME.. not a single fuse blown, nota single relay is bad, grounds are good.. DME is reading fine under bench testing.. and PIN 23 has continuity just when when isolated directly to ground from DME side..
        im thinking this 30h terminal on the starter is dead now, because i have zero volts for it on or off ignition.. i checked for continuity of the wire that runs from 30h to PIN 25 on the X20 round connector and its fine too.
        EDIT: correction PIN 15 not 25
        • Andrew325is
          • Jan 2008
          • 1212
          #259
          30h doesn’t go to pin 25. It’s pin 15. Pin 25 is the alternator charge indicator. Yeah 30h switches between ground and power for the unloader relays.
          • Th3 shifty
            • Sep 2016
            • 2
            #260
            youre right sorry, PIN 15.. so if its not showing volts under ignition ON, then its pretty much the solenoid on the starter has some kind of failure then?
            and this wire on pin 15, the supplies power or turns on the DME relay?
            • Andrew325is
              • Jan 2008
              • 1212
              #261
              It should be ground all the time except when it switches positive when you crank the engine (when the starter receives power at terminal 50).
              • M3 euro ltw
                Site Sponsor
                • 259
                #262
                Trying to reach Andrew
                I have a project for him, and can not reach him via the forum.
                If anyone has other ways to reach him, I respect privacy, so, I'm not asking for his phone or email, but if you could, let him know to check his PM and reach out to me.
                He will thank you, I'm sure.
                Alex Lipowich
                Trying to make the world a better place, 6 TB at a time.
                http://abloriginalparts.com/
                • Andrew325is
                  • Jan 2008
                  • 1212
                  #263
                  Alex Lipowich
                  It’s the weekend and I’m busy painting the truck. What’s up?
                  • M3 euro ltw
                    Site Sponsor
                    • 259
                    #264
                    PM sent to you.
                    • Andrew325is
                      • Jan 2008
                      • 1212
                      #265
                      It looks like the E30 coolant temp sensor is available from BMW again. Updated price on original post.
                      • Sean S.
                        • Aug 2012
                        • 196
                        #266
                        Just received my s52 harness from Andrew. Total quality product! All genuine connectors and pins, etc. Andrew has been great with answering any questions as well. There are cheaper adapters out there, but this is a case of truly getting what you pay for! Thanks, Andrew!
                        • Staszek
                          • 2533
                          #267
                          Although it was a month ago, here is the first start with Andrew's S54 harness!
                          • Andrew325is
                            • Jan 2008
                            • 1212
                            #268
                            Awesome! Beautiful car!
                            • r-mm
                              • Jun 2018
                              • 203
                              #269
                              Solid photo bombing by your cat. I'll be in touch when the time comes, looks like a quality product and service.
                              • Andrew325is
                                • Jan 2008
                                • 1212
                                #270
                                Announcing the spring sale! For a limited time you can have superior quality at a price lower than the competition.
                                Sale prices (effective 26 February 2019):
                                -$424.99 for S54 or S62 wiring adapter harness
                                -$399.99 for M54, M62TU, or M62 (9/97+) wiring adapter harness
                                -$374.99 for M52TU wiring adapter harness
                                -$194.99 for M50, S50, M52, or S52 wiring adapter harness for E30 (add $50 for OBD2 port for M52 & S52)
                                -$49.99 for Bench Flashing Harness for MS42, MS43, MSS54, & MSS52 ECUs
                                -$49.99 for Bench Flashing Harness for MS41 ECUs
                                Note that options/add-ons and ECU flash prices will remain the same.
                                Frequently asked questions:
                                Q. Will quality be lower at these low prices? Will inferior components be used?
                                A. No. Quality will remain the same. You will receive the same high quality components used on a harness purchased at regular price.
                                Q. Are you outsourcing the manufacture or hiring minions who will work at low wages?
                                A. No. All of my harnesses will continue to be manufactured by myself in Oregon.
                                Q. What do you do with the funds generated from harness sales?
                                A. I use the proceeds to fund my E30 & Defender 90 restoration projects and some of the money is donated to support local environmental and conservation efforts such as Friends of the Columbia Gorge and Oregon State University’s Marine Mammal Institute.
